pics would be nice....
Not uncommon, I'm pretty certain the numbers correspond to bore size so they could select fit the pistons ....John
Correct. The pistons were select fitted by the assembler. The bores were inspected after machining and marked so that all the assembler had to do was select the proper size piston / rod assembly to go in each hole.
