Author Topic: 68 Dearborn Safety Wire  (Read 3342 times)
Offline thefordshow
  • fordcountry@bell.net
« on: September 13, 2009, 06:16:43 PM »
May '68 dearborn car: Is this common routing of the safty wire used for the brake caliper bolts, or should one wire run from bolt to bolt? [doesn't look to be changed, but after 40 years??]
« Last Edit: November 26, 2019, 07:28:10 PM by J_Speegle »
Re: 68 Dearborn Safety Wire
« Reply #1 on: September 13, 2009, 09:03:11 PM »
Have always seen original ones with an individual wire for each bolt.
Here is another example - this one from a 69 San Jose car
« Last Edit: November 26, 2019, 07:28:18 PM by J_Speegle »
Offline thefordshow
« Reply #2 on: September 13, 2009, 09:14:59 PM »
Thanks Jeff, I'll do it back that way then.
« Last Edit: November 26, 2019, 07:28:25 PM by J_Speegle »
« Reply #3 on: September 14, 2009, 12:29:42 AM »
Another example shows the way the wire was wrapped  unique to big suspension 69/70  Shelby's and Boss cars.  The twice around the spindle seems to be a identification indicator. Just to be clear this was done BESIDES the seperate safty wire in the bolts. Bob
« Last Edit: November 26, 2019, 07:28:32 PM by J_Speegle »
« Reply #4 on: November 26, 2019, 07:48:12 PM »
Been over ten years since this thread was last posted to but ran across some pictures (posted in another thread) that I thought would help here. Was going through the safety wire pictures looking for ones to use for another thread
Hope these helps
Believe these are 68 though off the car so can't be certain of which plant they were done at
