Author Topic: bracket/backside panel color  (Read 2482 times)
Offline BuckeyeDemon
    • Photobucket Pictures
« on: November 06, 2010, 11:18:24 AM »
for the 69 dearborn mustang in my signature:
For the following body panels, i've seen most completed that had the back side body color.  I'm not sure if these were restored correctly or what they thought was correct.
1.  Front Fenders
Should the backside of fenders be finished in red oxide?  Underneath the sound deadner on my originals i did find red oxide.  I don't believe they were topcoated with the candyapple red.
2.  Stone Deflector (Front Bumper)
Similar to item 1, except the backside of my original was all surface rust.
3.  Front Valance
Should the backside of the valance be red oxide, red oxide with a little topcoat overspray, or fully topcoated?  My original is long gone...
4.  Rear Valance
Based on what i've read, it seems the backside should be red oxide with a minor amount of topcoat overspray since it was painted somewhat hanging on the car.  Can anyone verify?
For the following parts, I'm guessing they are "slop gray".  Most of the following items I've seen finished in a shade of black, but on a few occasions i've seen them a gray tone or I haven't found any direct mention of these items.
I had a gray mixed to spray these parts and will add black to the mixed gray paint to alter the shade from part to part...
1.  Front License Plate Bracket
My original was long gone...
2.  Front Valance Support Bracket
(about 8" long and attaches on the bottom hole to the bumper bracket in the wheel well).
My original was heavily rusted
3.  Front Fender extension to radiator support bracket
(~4" long L-shaped)
My original appeared to be very lightly surface rusted.
4.  Grill Support Brace
(D-shaped bracket)
5.  Front Bumper to Valance Bracket
(small ~2" flattened z shape)
6.  Front Bumper Arm
(smaller long tubular bracket that mounts to the outside of the large bumper bracket)
i have no idea where my originals went.
7.  Lower Radiator Saddle Mounts
were these painted separately and added to the car after the engine compartment was painted?  should they be semi-gloss black?
« Last Edit: November 06, 2010, 01:06:19 PM by BuckeyeDemon »
VIN: 9F02M178303
Build Date: March 31, 1969
1969 Mach 1, Candyapple Red, 351W 4V
Re: bracket/backside panel color
« Reply #1 on: November 09, 2010, 01:08:02 AM »
Nice long list ;)
Lets give this a try
1.  Front Fenders
The fenders were delivered in red oxide and during the paint process would receive a little or allot of overspray from the process. Allot to a very nice coat was applied to those surfaces directly behind the exterior surfaces. So as you look at the wheelwell opening (for example) those surfaces directly behind  (the bottom surface of the fender ) would receive a nice coat of paint, This could be more concentrated towards the center (since the gun would have been closer at that point) than further out towards the ends. Same goes for the area on the back side of where the head light bucket would attach. Since it faces the wheel well opening is normally got a nice coat of paint. So just look at it logically and where the majority of the heavier overspray goes will become apparent
Since there is little reason on this piece to apply any paint at even a 90 degree angle of the bottom these panels often little more than a dusting of exterior color over the red oxide primer sealer
3.  Front Valance
Like the fenders - light overspray to not much at all except where the paint was applied at an angle. On the front valance this would be at the ends where the painter would be painting the surfaces that would attach to the fender or the paint that would have gone through the areas where the turn indicator would mount
4.  Rear Valance
Red oxide with very light dusting to nothing along the top edge except for the ends where more would have entered during the paint process. On your car all of the mounting screws would have been paint
-For the following parts, I'm guessing they are "slop gray".  Most of the following items I've seen finished in a shade of black, but on a few occasions i've seen them a gray tone or I haven't found any direct mention of these items.
-I had a gray mixed to spray these parts and will add black to the mixed gray paint to alter the shade from part to part...
Good idea
Just a thought but if you read the FAQ at the top of the 69-70 section you will find most of these included ;)
Yes - slop gray for your year and plant
3.  Front Fender extension to radiator support bracket (~4" long L-shaped)
(D-shaped bracket)
Hood latch support bracket - Yes - slop gray for your year and plant
5.  Front Bumper to Valance Bracket (small ~2" flattened z shape)
Don't believe so
6.  Front Bumper Arm
Semi-gloss black
Also painted slop gray (that year and plant) was the battery box/tray, the front coil spring cover and shock tower supports
Offline PerkinsRestoration
« Reply #2 on: November 10, 2010, 11:56:34 PM »
I think #6 is reversed? The tubular bracket should be black and the inner  bracket is gray?
« Reply #3 on: November 11, 2010, 12:03:13 AM »
Thanks Bob for the correction - long list ;)
