Author Topic: Lower Radiator Brackets 1968-70 - Variations  (Read 2299 times)
« on: February 27, 2019, 08:54:03 PM »
Here are 4 different versions of the lower brackets for 24 inch radiators as found on 1968-70 Ford Mustang and Mercury Cougar. We have a local metal fabricator that is willing to make a better reproduction bracket than is offered by Scott Drake.
I have arranged my used brackets as I think they may have been installed. 1968 on the left, ending with 1970 on the right. Am willing to accept suggestions from the forum for which version gets submitted for possible reproduction.
Re: Lower Radiator Brackets 1968-70 - Variations
« Reply #1 on: February 27, 2019, 10:41:09 PM »
So what is the guiding principle?  Which one we believe has a greater demand?
« Reply #2 on: February 28, 2019, 12:12:34 AM »
Yes, looking for feedback and suggestions.
When I went looking for samples, I knew that there were at least 2 different versions. Wasn't surprised by 3, but the 4th one took me by surprise.
Offline TLea
« Reply #3 on: February 28, 2019, 07:11:18 AM »
Hi Scott. This is a much needed part  and current Reproductions are horrible. I’ll put in my vote for the 68 version
Offline Al Bundy
« Reply #4 on: February 28, 2019, 10:03:56 AM »
I would vote ‘68, but I’m somewhat confused how there are four pictured from 68-70.  Obviously two must be from the same year, but which two?
1974 Dodge Dart - daily driver
1963 Thunderbird Z code - raven black/red
1968 XR7 F code - diamond blue/blue
1968 XR7 J code - black/red
1968 J code - madras blue/aqua
1968 XR7 X code - lime frost/dark ivy gold
1968 GT-E XR7 W code prototype no. 500033 - cardinal red/black
Offline Brian Conway
« Reply #5 on: February 28, 2019, 11:47:43 AM »
The second from the left looks the most like the ones on my 69.  Hard to tell with out doing a side by side ?  It seems any variation in height would be a major consideration ?  Brian
5RO9A GT  4 Spd Built 5/29/65
9TO2R SCJ 4 Spd Built 9/19/68
Owner Driver Mechanic
San Diego, Ca.
« Reply #6 on: February 28, 2019, 12:12:53 PM »
I would not expect this bracket to have a clean cutoff by year, there very likely would have been some overlap. For example, from a manufacturing stand point, Ford may have placed and initial order of 200,000 sets of those brackets. The subsequent runs look like they were trimming metal from the brackets to save money and weight? Kind of a common practice.
Tim and others. Do you agree that the one pictured on the left is the 1968 version?
« Reply #7 on: February 28, 2019, 09:12:26 PM »
Yes I would agree the one on the left is the 68. That is the one I hope is reproduced for selfish reasons.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #8 on: March 01, 2019, 11:24:24 AM »
Scott....I put this together a while back and may be useful for identifying the lower brackets.
http://anghelrestorations.com/uploads/3/5/1/2/35122002/radiator_brackets_v1.2.pdf
Marcus Anghel
www.anghelrestorations.com
« Reply #9 on: March 01, 2019, 11:41:54 AM »
Thanks Marcus, I did use that information to verify the 1970 or 'last' factory version.
« Reply #10 on: March 01, 2019, 09:41:31 PM »
Being challenged at seeing the defining details for each version of brackets in my pictures in any volume that would seem helpful. Especially when the differences can be viewed best (installed) from under the car.
Which ever version you choose will mean that you'll likely have to note that there are other versions or years not being reproduced at the time.
Based on the largest production period I believe you may choose one of the two middle versions.
What I can offer are the following observations
#1 appears to change somewhere after 8T20926x
and some point before 8F21024x  - Yes two different plants just offering data points.
#2 I found used originally on 9F18838x, 9F20888x, 9F21490x,
Since the "cut away" on the lower support arm is positioned above the rear lip of the front cross member I found it difficult to even see that detail once installed in pictures from almost every angle.
Sorry I tried to help more also didn't get through my Shelby pictures :( but its been a couple of days and wanted to respond .
« Reply #11 on: March 02, 2019, 12:58:24 PM »
I looked at the ones on my '68 R code. They match Scott's photo. Installed on the car, there is not any way to tell conclusively. I had to go look at photos of them while restoring them to see the differences.
« Reply #12 on: March 02, 2019, 02:41:36 PM »
Royce, your bracket looks like my second photo?
« Reply #13 on: March 02, 2019, 04:53:00 PM »
No, like the first one.
« Reply #14 on: March 02, 2019, 06:01:35 PM »
Looks like the second version (from the left) in your first (top) picture. Or picture number one. :)
Since it doesn't have the notch, from the top view, at the lower right in the picture. Could be even the third one since we can't see the support leg on Royce's example. He can likely provide/confirm that detail
