Author Topic: 69 Firewall Electrical and Cable Retainers  (Read 2590 times)
« on: February 22, 2019, 04:42:58 PM »
There are posts attached (welded) to the face of the firewall on 69 and 70 Mustangs on the engine compartment side.  The subject of one of these retainers came up on another site recently so in response to that thread I went through pictures and collected and looked at what I could find related to the subject.
It appears that a number of different style retainers were used (have four so far) depending on what was being retained/secured, what assembly plant and during what time period. Have not do a in-depth look yet,  may not have enough data yet to provide a complete picture,  but wanted to offer some pictures and what I had found so far related to just 69 Dearborn findings
Here are a few pictures of them installed sorry they could not be much clearer or free of obstruction. They are a pain to take off without breaking them and were used for different purposes depending on Mustang and Shelby model.
Holding a speedo cable on a four speed car. These are reported to now be available in reproduction form.
Close-up of a flatter version most often found, so far, retaining wire looms in this case for the neutral safety and back up lights
They can also be found used elsewhere on the firewall depending on model, time period and plant. Lower one is broken likely by someone jerking on what ever was in that clip. These appear to be faded from exposure to the sun. Looks like its possible that this was an Oklahoma yard picture
  During the production years the flat style of wire strap/retainers were sometimes used. Similar style (though possibly different) to those are like the style found at the drivers side rear of the engine compartment that hold the windshield washers hoses to the firewall.  This one was being used for the speedo cable for a four speed car like the first picture above.
Re: 69 Firewall Electrical and Cable Retainers
« Reply #1 on: February 23, 2019, 01:17:17 AM »
Jeff u got a better photo of J-strap like on your first photo holding speedo cable as thats the round hook type j-strap just made & in your second photo the flat type wireing holder also just made. The round speedocable type i have also seen holding wires to firewall just below throttle cable.
Offline Wills70
« Reply #2 on: February 23, 2019, 02:08:32 PM »
These are a couple off some parts cars years ago , so I cannot verify these are 69 or 70s. Would these be the 4 speedo clips?
Thanks Will
« Reply #3 on: February 23, 2019, 05:30:26 PM »
I'll look but don't believe so. If one is still there then most of the time the engine and other items are in the way for a nice picture. If out and in a yard (stuff out of the way) the clips gone :(  allot of the time or I would have a handful out in the garage.
« Reply #4 on: February 25, 2019, 08:29:55 PM »
I'd like one of those retainers for my speedo cable.  Is there a vendor ?  Thanks, Brian
« Reply #5 on: February 25, 2019, 08:48:52 PM »
This tread should help but it will not provide a direct link to the maker. I'll PM them on that site (since you might not be a member) and pass that one if it will help
http://www.boss302.com/smf/index.php?topic=81124.msg536006#msg536006
« Reply #6 on: February 26, 2019, 10:33:04 AM »
Thanks Jeff.  I am a member of that site.  I sent Eddie a PM and will wait and see if that gets a response.  Brian
« Last Edit: February 26, 2019, 11:04:06 AM by Brian Conway »
« Reply #7 on: February 26, 2019, 06:02:41 PM »
For others he got back to me and I was informed they should be on the Dead Nuts On site soon
« Reply #8 on: February 26, 2019, 08:34:47 PM »
OK Dead Nuts has them.
« Reply #9 on: February 26, 2019, 09:11:39 PM »
Or will in the very near future and Jack get the order page posted  ;)
« Reply #10 on: February 27, 2019, 12:38:39 PM »
So I am looking for the post to hang the speedo cable clip from and I don't have one ?  Early Metuchen car does have the upper reverse harness post.  Probably should be on the raised circular bump ?  Brian
« Reply #11 on: February 27, 2019, 02:42:15 PM »
Don't know. If you notice the other examples above don't appear to have a raised "bump" in that area of the firewall that shows in your picture
First step I believe is to see if the early firewalls had the same posts as later versions. Will see what I have and maybe we'll see if this splits off to a new discussion and finding
« Last Edit: February 27, 2019, 02:44:16 PM by J_Speegle »
Offline Armond
  • Silver Level Subscriber
    • D'Agostini Restorations.com
« Reply #12 on: February 27, 2019, 08:48:52 PM »
Jack at deadnutson now has the speedo and wiring clips for the firewall available.
https://www.deadnutson.com/1969-70-firewall-speedometer-cable-clip/
MCA#31064
« Reply #13 on: March 01, 2019, 12:37:22 PM »
Got a short note from 'DeadNutsOn', I assume from Jack, saying he has noted this anomaly, missing post, before. Brian
« Last Edit: March 01, 2019, 01:08:36 PM by Brian Conway »
Offline 1970 Snake
« Reply #14 on: March 02, 2019, 11:32:04 AM »
Hi, interesting thread I was looking for my original J-clip a while back for assembly and finally found it, glad to see Jack now repro's them. I realize your posting 69 cars but decided to post a pic of my original disassembly which shows the original clips on my very early build Dearborn 1970 Mach1, which actually has a number of 69 parts on it which where assembly line installed. The J-clip was used to hold the C-6 floor shifter light wire and the flat strap closest to the booster held the C-6 neutral switch wire and the other to hold another wiring harness I believe.
« Last Edit: March 02, 2019, 11:52:07 AM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
