Author Topic: Sway bar Bolt Direction?  (Read 1275 times)
Offline ChrisV289
« on: February 21, 2019, 11:12:31 AM »
So I’ve been watching the progress on Branda’s son restoring a 64.5 pace car and the direction of the bolts on the sway bar came up. He has the built facing up with the nuts on top of the frame rail and the head of the bolt underneath. I thought it went the other way. Is there a correct way or is it like the coil spring covers where Dearborn did one way and San Jose did another way? Did a search and didn’t find anything on the forum
2009 V6 Mustang Coupe
Re: Sway bar Bolt Direction?
« Reply #1 on: February 21, 2019, 11:30:58 AM »
got a link to this??
Offline ChrisV289
« Reply #2 on: February 21, 2019, 11:38:49 AM »
It’s on Facebook. He posts photos of his progress
« Reply #3 on: February 21, 2019, 12:05:22 PM »
i don't do f/b. thanks.
« Reply #4 on: February 21, 2019, 12:33:29 PM »
Me neither.
Nut on bottom.
Offline rrenz
« Reply #5 on: February 21, 2019, 02:12:53 PM »
Hey Chris could you send me the info on this page or where they’re posting these. Would be interested to see this.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
« Reply #6 on: February 21, 2019, 03:51:35 PM »
Not that it's something specific to Pace Car coupes, but the one I restored had the bolts in the up direction with the nut on top of the sway bar connection.
« Reply #7 on: February 21, 2019, 04:01:37 PM »
Looks like you have a number of items and I personally would rather not comment on someone else's efforts that has not asked for it in a public forum. ;)
Guess as part of your question your asking about the direction of the bolts that hold the coil spring covers to the engine compartment. Yes they were installed in different directions (should be a number of examples in pictures in the Unrestored Picture section of this site) depending on where the car was built.
As for early Dearborn built cars here are four quick (have more) pictures I offer
Offline ChrisV289
« Reply #8 on: February 21, 2019, 04:10:58 PM »
Not the end ones. He has since switched them around but thought maybe someone else might have seen them go the other way.
« Reply #9 on: February 21, 2019, 04:22:49 PM »
You did say "frame rail" as opposed to "lower "A" arm" so there should have not been any confusion. I've seen a couple of 65-66 Shelby sway bar bolts from the bottom, but attribute that to being a Shelby peculiar installation, maybe even "owner" installed.
« Reply #10 on: February 21, 2019, 05:23:22 PM »
I missed the frame rail mount.  They definitely should point downward.
« Reply #11 on: February 21, 2019, 06:54:46 PM »
+1 Me also. Guess that its due to eh fact that the end link swap bar hardware has been such a much discussed detail over the years so just assumed that it returned for discussion again.
Two examples from each plant for 65 but didn't hunt through to narrow the search just to the Dearborn Pace Car period. Likely could do that if needed.
NOTE: Hardware details can differ between plants and years.
« Last Edit: February 21, 2019, 07:08:55 PM by J_Speegle »
« Reply #12 on: February 21, 2019, 07:05:45 PM »
As a reference, the pace car I restored had RBW sway bar frame mount bolts.  I had the originals re-plated as there is no reproduction available.
