Author Topic: OE Style Engine Oil Pan Drain Plug ~Pictures  (Read 1707 times)
« on: February 19, 2019, 03:21:25 PM »
I believe this should be a "Standard Part" over the Classic years but does anyone have close-up shots of original Engine Oil Pan Drain Plugs?
Looking for a 67 289 in particular but I don't think there were many versions (for engine options/years).
Re: OE Style Engine Oil Pan Drain Plug ~Pictures
« Reply #1 on: February 19, 2019, 05:01:24 PM »
Here are two examples from 65 small block applications
5R1508xx
5F2706xx
« Reply #2 on: February 19, 2019, 05:04:28 PM »
Thanks Jeff. I bought an aftermarket one that looks just exactly the same (that is 'same' once I remove the embossed lettering). That was what I was hoping to see.
« Last Edit: February 19, 2019, 05:06:45 PM by 67gtasanjose »
« Reply #3 on: March 10, 2022, 06:16:40 PM »
There may be more than one correct style, as Jeff's pics show.
I have a few in known original pans and one has the mark "F  - C" and the other is mostly flat but has the circle raised embossment area where the bolt shank would be. They both have a "pilot" on the threaded side.
The original nylon washers appears to be fairly thin -- thinner than those you buy at the box stores (left in pic 2).
« Last Edit: March 11, 2022, 01:38:02 PM by Bossbill »
Offline dkknab
« Reply #4 on: March 12, 2022, 05:38:43 PM »
Sorry everyone. I guess I didn't look hard enough for this info. I too am looking for a drain plug for a 68 289 Sprint B. Here's a picture of the one I have and need a good replacement. Any suggestions? Also, is the gasket black or white?
David Knab
289 2V, AT, PS
Nugget Gold Interior
« Reply #5 on: March 12, 2022, 10:25:40 PM »
The two pictures I posted were of one of each  -plain and with the F-C.
Another look of that same car/plug (with a little adjustment to the contrast) with a better look and with the painted metal gasket
