Author Topic: 67 hood latch and dowel finishes  (Read 1380 times)
« on: February 17, 2019, 04:02:32 PM »
I think I have read enough to say that the hood latch should be finished in phosphate & oil.  Should I remove the springs or leave the assembly intact?
I did read about short and long style latches and wanted to add the following reference information:
1. The January 67 MPC calls out C7ZZ-16700-A
2. The August 67 MPC calls out C7ZZ-16700-B for 67
3. The August 67 MPC calls out C7ZZ-16700-C for 68
So it appears that there were three versions, and perhaps the "late 67" and 68 versions are different.
On a related note, the 16921 spring - hood latch trigger is:
1. C6OZ-16921-A - coil type-curved ends for "before 4/17/67" and
2. C6OZ-16921-B - identified with yellow paint for "from 4/17/67"
The spring change affected Mustang, Fairlane, Falcon, and Thunderbird, so may not be related to a C7ZZ-16700-A to C7ZZ-16700-B transition.
Secondly, I'm looking for confirmation of the "dowel - hood latch" C7ZZ-16929-A.  The post linked below, if I read it correctly, has Bob G recommending zinc phosphate.
http://www.concoursmustang.com/forum/index.php?topic=12339.msg75080#msg75080
The 2019 MCA rules calls for the "release" and "latch" to be phosphate and oil.
To summarize, three questions:
1. Hood latch finish?
2. Refinish hood latch as a complete assy or remove the springs?
3. Hood latch dowel ("L" shaped striker) finish?
Thanks!
Re: 67 hood latch and dowel finishes
« Reply #1 on: February 17, 2019, 05:04:33 PM »
P & O to both items and I always remove and refinish the springs separately since I don't want to use high heat and affect the springs tension
Just my choices
« Reply #2 on: February 17, 2019, 05:25:41 PM »
The phosphate process uses a mix of phosphoric acid and hot water between 190F and 212F (boiling). The maximum time would be around 10 minutes. That temperature range and time will not affect temper.
« Reply #3 on: February 17, 2019, 10:14:27 PM »
Thanks!
In that thread the discussion was about the E brake idler arm. The hood latch and catch should be P&O.
Offline Fastback2013
« Reply #4 on: April 23, 2019, 04:22:53 PM »
In attachment picture of my hood latch.
I see that there's a bit of white paint, is that supposed to be so or not?
Is it overspray or must that (only) piece covered with body paint?
San Jose 7R02C1708xx
Fastback GTA
built on 01/12/1967
« Reply #5 on: April 23, 2019, 04:31:22 PM »
The hood was painted off the car with no attaching anything. The latch was installed either prior to the hood going on, or after the hood hinges were installed on the hood/body and adjusted. It's probably rattle can overspray you see.
« Reply #6 on: April 23, 2019, 05:34:07 PM »
Agreed - No paint on hood latch. It was not installed when the hood was painted. Likely overspray from a touch up or repair
68 Example that was handy. Sure there are a number of examples if you look in the picture section of this site with the unrestored cars
« Reply #7 on: April 24, 2019, 05:53:45 AM »
Thanks, Jim and Jeff!
Fastback GTA
built on 01/12/1967
« Reply #8 on: April 24, 2019, 12:31:37 PM »
You're welcome. Remember, what ever you do decide to do, think of keep rust and corrosion to a minimum.
« Reply #9 on: April 24, 2019, 04:53:35 PM »
I posted a picture of 67 style hood latch with shorter guide teeth for comparison.
