Author Topic: 1967 GT500 Dip Stick Ford Part Number?  (Read 1915 times)
1967 eight barrel
  • Guest
« on: February 17, 2019, 04:17:49 AM »
I have a Cobra Aluminum T-sump Cobra pan. It is listed as a 6.5 quart capacity. When there is 7 quarts in the pan it registers right at the Add line. I have the dip stick that was in the vehicle when purchase in 1982 and I wanted to confirm the number stamped as correct for application.  It is stamped: C7AE-6750-A. I do have the factory Ford windage tray, which I haven't heard of anyone having interference issues with.
 I remember reading that there was a TSB that required the change of the dip stick which changed the indicator marks for the added oil capacity. ( 6 quarts)
I thought that would make sense under the circumstances.
        -Keith
« Last Edit: February 17, 2019, 04:23:51 AM by 1967 eight barrel »
Re: 1967 GT500 Dip Stick Ford Part Number?
« Reply #1 on: February 17, 2019, 08:44:34 AM »
        -Keith
I have read that TSB also. I checked the library for the TSB and did a quick search to no avail. That seems odd I cannot find it either.
« Last Edit: February 17, 2019, 09:25:16 AM by 67gtasanjose »
Offline 67_1183
« Reply #2 on: February 17, 2019, 01:37:35 PM »
The stock 67 GT500 dipstick in #1183 is marked C7OE and FoMoCo.
2nd owner of 1967 GT-500 #1183 since September 1976
Offline 196667Bob
« Reply #3 on: February 17, 2019, 01:39:27 PM »
Richard : Before I do any more digging through my TSB's, the attached isn't the one you were thinking of , is it ? It doesn't cover the 6.5 qt oil pan.
Bob
MCA 04909
Offline 196667Bob
« Reply #4 on: February 17, 2019, 02:45:05 PM »
In looking through the "Monthly TSB Indices, I did find one other, although dated September 27, 1968. This is probably the one Richard was remembering.
Bob
MCA 04909
« Reply #5 on: February 17, 2019, 02:56:37 PM »
I did not logg it into my memory as "needed to know" but I understand it was for the 6 or 7 quart engines, like the OP's request.
1967 eight barrel
  • Guest
« Reply #6 on: February 17, 2019, 03:46:44 PM »
Here is the OE dipstick. I had it replated. I have replaced the original tube with a Scott Drake tube.
              -Keith
« Reply #7 on: February 17, 2019, 04:09:27 PM »
Here is some MPC info - has information on marking lengths
1967 eight barrel
  • Guest
« Reply #8 on: February 17, 2019, 04:16:31 PM »
The only difference between the C7AZ and C7OZ is the chrome handle.
        -Keith
