Author Topic: Correct finish 1965 Spindles  (Read 1006 times)
Offline Mustanggirl65
« on: February 11, 2019, 12:13:21 PM »
What is the correct finish for 1965 V8 spindles?  Build date 11/10/1964.  Thanks!
1965 Wimbledon White Fastback, SJ 11/10/1964
         74,500 miles, Unrestored
2015 Ingot Silver Premium GT 50th Anniversary Package
Re: Correct finish 1965 Spindles
« Reply #1 on: February 11, 2019, 12:20:27 PM »
It is the same for the other year spindles . It is a medium gray heat treated steel finish . Some describe it as a blueish gray. If you have a metal shop close by you can pick up a small scrap sample to hold in your hand to go by. Someones that is better then trying to match from a monitor which may give false color hues.
« Reply #2 on: February 11, 2019, 12:49:39 PM »
Gotcha!  Appreciate the info!
« Reply #3 on: February 11, 2019, 06:22:32 PM »
First welcome to the site. Hope you find the information and the support here helpful in your concours related endeavors
You will find that the search feature will help you allot answering questions like this. Also the Library has a number of articles you might want to check out also.
There is a "Reproducing Natural Finishes" article
A few of the prior threats for your viewing. Term used was "spindle finish"
http://www.concoursmustang.com/forum/index.php?topic=17351.msg109900#msg109900
http://www.concoursmustang.com/forum/index.php?topic=5996.msg33861#msg33861
http://www.concoursmustang.com/forum/index.php?topic=13743.msg85744#msg85744
http://www.concoursmustang.com/forum/index.php?topic=5890.msg33184#msg33184
http://www.concoursmustang.com/forum/index.php?topic=462.msg2314#msg2314
http://www.concoursmustang.com/forum/index.php?topic=8723.30
http://www.concoursmustang.com/forum/index.php?topic=473.msg2370#msg2370
« Reply #4 on: February 13, 2019, 03:37:32 PM »
Jeff, thank you for the links.  I have enjoyed those and exploring the site for information.
Still need to check out the Library!
