Author Topic: San Jose 1966 - Tung Sol Ford Etched Headlights?  (Read 954 times)
Offline Morsel
« on: February 04, 2019, 01:23:12 PM »
Does anyone know what the difference is between the Tung Sol Ford Etched headlights... there is a 4002 series and a 6012 series, the Rotunda box number on the 6012  series is R 12-D, and R 12-B on the 4002 series...
So which was the correct ones and what's the actual difference? High and low beams?
Thanks as always for any info,
Jason
Offline 196667Bob
Re: San Jose 1966 - Tung Sol Ford Etched Headlights?
« Reply #1 on: February 04, 2019, 10:43:14 PM »
Here are the answers to some of your question : see attached from the 1967 Only Parts and Accessories Catalog (1967 MPC). The 1965 and 1966 single year MPC's are identical.
The "R-x" numbers are Rotunda's designations. Of course neither address any etchings or embossments.
Bob
MCA 04909
« Reply #2 on: February 05, 2019, 12:13:13 AM »
Looks like the chart answers your question. All of the ones I have pictures of at 6012's
Offline Morsel
« Reply #3 on: February 05, 2019, 11:49:35 AM »
Thanks guys, I appreciate the response and sounds like the 6012 ones are the ones I want, have one of those already, proper with the etched Ford logo.
So one more for my curiosity, what’s the deal with the headlight bulbs when they say High beam and Low beam on the MPC list?
Thanks again,
Jason
« Reply #4 on: February 05, 2019, 01:32:00 PM »
Thanks again,
Jason
Other Ford vehicles had two bulbs on each side: a low beam and a high beam!
« Reply #5 on: February 05, 2019, 01:52:21 PM »
Other Ford vehic3les had two bulbs on each side: a low beam and a high beam!
More specifically, the "4-bulb headlight system" used a high beam/low beam 4-1/2" bulb in the outer or upper ~pending whether mounter horizontally or vertically.
The inner or lower bulb on the 4-bulb system would be High Beam Only.
Examples:
a 69 Mustang uses a horizontal 4 bulb headlight system.
a 66 LTD uses a vertical 4 bulb headlight system.
« Last Edit: February 05, 2019, 01:54:30 PM by 67gtasanjose »
Offline AU Finger
« Reply #6 on: February 05, 2019, 01:58:02 PM »
A= full size Ford, B=Fairlane, F=Mustang, X= Falcon, U=Bronco
May 25, 1964 D code convertible
Offline Morsel
« Reply #7 on: February 05, 2019, 03:09:29 PM »
Yep, makes sense everyone, thanks for all the responses & info.
Jason
