Author Topic: Cut back upper control arms  (Read 909 times)
Offline preaction
« on: February 03, 2019, 05:12:01 PM »
Looking through older threads this is mentioned but not defined IIRC this has to do with the shape of the UCA that faces the car when mounted, does this apply to 68 and up UCA until the use of the 3 rivet UCA ?
Re: Cut back upper control arms
« Reply #1 on: February 05, 2019, 09:09:50 PM »
The first picture is a un cut UCA. The second is a cut back 68 UCA. The cut back weakened the UCA and cracks are often found in them. That may have lead to the redesign.
Offline preaction
« Reply #2 on: February 06, 2019, 04:39:41 PM »
Marty, thanks for the reply I also noticed a single digit stamped on the front edge of your UCA and this is also seen on some of the UCA's in previous posts would the number stamping typical ?
« Reply #3 on: February 06, 2019, 05:28:44 PM »
Many times the stamping is so light on these and other UCA's as to make it indistinguishable.
« Reply #4 on: February 06, 2019, 05:38:37 PM »
Typically two digit. You can make out the first barely next to the easier to the deeper stamped digit to the right
Also a very small stamp/font was used when you can see it.
69 Example
« Last Edit: February 06, 2019, 05:42:50 PM by J_Speegle »
Offline preaction
« Reply #5 on: February 09, 2019, 02:00:38 PM »
Jeff thanks for the pics, is there a known reason for the cut back UCA and is there a expected plant and time frame these parts would be seen or used ?
« Last Edit: February 13, 2019, 12:58:21 PM by preaction »
« Reply #6 on: November 11, 2019, 07:04:34 PM »
Make sure that you inspect those control arms for cracks. While looking for a set of rebuildable uppers for a customer, I was disappointed to find cracks in this assembly line survivor with original rivets.
