Author Topic: Engine ID Tag Code  (Read 621 times)
Offline ChrisV289
Engine ID Tag Code
« on: January 29, 2019, 09:50:02 PM »
Trying to determine of the engine ID tag I have is correct for my SJ blue fastback (build date June of 65).  The engine tag says 563-J.  The website below says that it is for a K code but it is an A code.  Can anyone confirm this code is for a K or A code or if my manifold or engine tag was swapped at some point.  The date code matches up as 5-D
2009 V6 Mustang Coupe
Re: Engine ID Tag Code
« Reply #1 on: January 29, 2019, 10:14:35 PM »
Bob Mannel's book decodes it as K code, from a Fairlane, with manual transmission.
Offline ChrisV289
« Reply #2 on: January 30, 2019, 11:16:38 AM »
Interesting. The car was a four speed originally. Is there anything on the manifold or block to tell me this motor was out of a Fairlane? The engineering numbers are technically the same, correct? I can’t say for certain this motor is original  to the car
« Reply #3 on: January 30, 2019, 05:17:26 PM »
There is more info on the tag that might help figure out where it came from (out of)
"The date code matches up as 5-D"
Matches up with??  Block casting date, head casting dates, block assembly date, carb.......?
Offline ChrisV289
« Reply #4 on: January 31, 2019, 08:11:42 PM »
The car has a "projected"build date of 04T.  The tag reads as follows:
289  65  7
5-D  563-J
I can't see the assembly date due to the AC compressor.  I plan to change the oil pan so hopefully i can see it there.  I will check the date codes on the manifold and block soon
