Author Topic: 1967 AC Hot water control valve  (Read 1028 times)
Offline BKnapp
« on: January 29, 2019, 09:06:58 PM »
Can anyone tell me what screws are used to hold the valve to the bracket? I don’t see them on Jim’s spreadsheo, likely due to it being part of an assembly.
Also, want to verify that the bracket and the vacuum assembly are both dichromate finish.
Re: 1967 AC Hot water control valve
« Reply #1 on: January 30, 2019, 12:32:28 AM »
Believe they were slotted head machine screws. Sorry don't know the size and looking for a picture to confirm. Original finish was goldish for the valve and bracket. Main body of the valve is brass or bronze it appears
« Last Edit: January 30, 2019, 01:09:34 AM by J_Speegle »
« Reply #2 on: January 30, 2019, 12:43:48 AM »
Found these hope this helps
Online 67gta289
« Reply #3 on: January 30, 2019, 05:49:29 AM »
Here is a related thread, for cross reference purposes-
http://www.concoursmustang.com/forum/index.php?topic=11918.msg72027#msg72027
Offline BKnapp
« Reply #4 on: January 30, 2019, 08:33:40 AM »
Thanks guys. I thought the mounting screws for the valve are 8-32. The ones I removed fit on to a 8-33 nut, but they are pretty corroded. The 8-32 x1/2 screws I bought seem to bind and I don’t want to strip the threaded brass valve. Could be 8-36, but I haven’t been able to find them locally...seems to be uncommon, or I’m just not looking in the right place.
Offline BKnapp
« Reply #5 on: January 30, 2019, 03:10:17 PM »
Just to confirm...I did get the 8-32 to thread in smoothly.
Thanks for the pics and other input.
« Reply #6 on: January 30, 2019, 04:28:34 PM »
Is there a gasket between the bracket and valve?
Online 67gta289
« Reply #7 on: January 30, 2019, 06:06:49 PM »
no gasket - there is an o-ring.  see the post referenced in reply #3
Offline BKnapp
« Reply #8 on: January 30, 2019, 06:52:45 PM »
Although I can not attest to the originality of mine, I have taken 2 apart and both appeared to have had a paper/felt gasket. I assume an o-ring would work fine, but not sure what was originally used.
Online 67gta289
« Reply #9 on: January 30, 2019, 09:28:24 PM »
Bill, that could very well be the case.  I assumed it was an o-ring.
« Reply #10 on: January 30, 2019, 11:14:07 PM »
Paper/felt gasket is what I have found many times which has lead me to the same conclusion. A "O" ring is what I have always successfully used as a substitute.
