Author Topic: 1966 289 (HiPo) Exhaust Manifold to Engine (Gasket or no Gasket)  (Read 1501 times)
Offline Morsel
Hey all,
I was searching through the forum looking for info or a picture of a exhaust manifold gasket, searching this subject I ran across an old thread and Bob mentioned that no gasket was used on the standard 289 and 289 HiPo's, so I just want to confirm this, if there was a gasket, I sure can't find any info on a part number or visual of what these looked like. Any clarification would be helpful...
Jason
Re: 1966 289 (HiPo) Exhaust Manifold to Engine (Gasket or no Gasket)
« Reply #1 on: January 29, 2019, 06:58:07 PM »
you can stop looking. ford did not use any gasket there.
Offline Morsel
« Reply #2 on: January 29, 2019, 06:58:52 PM »
Great, thank you, exactly what I was looking for, the truth ;)
J
« Reply #3 on: January 30, 2019, 12:30:18 AM »
Yes - easy to remember. No gasket at those surfaces for any of the classic V8's
« Reply #4 on: January 30, 2019, 09:41:04 AM »
If there ends up being a leak, can try getting the mating surfaces machined.
Offline Morsel
« Reply #5 on: January 30, 2019, 01:13:02 PM »
Yeah, going to have the exhaust manifolds machined prior to restoration and probably use Bob's method of a small amount of RTV High Temp Silicone just to ensure I get a seal... unless someone tells me that's a bad idea ;)
Jason
« Reply #6 on: January 30, 2019, 02:17:12 PM »
Often you can still see the sealant - especially the red stuff :(
Last engine I used graphite between the surfaces like is called out in the original engineering drawings and instructions on many of the period Ford engines. Worked out well so far.
Offline Morsel
« Reply #7 on: January 30, 2019, 07:14:09 PM »
Ah, interesting, I like that graphite idea, may give that a try instead, why not, if it was good enough for them ;) And I would never use RED RTV :)
Thanks Jeff...
« Reply #8 on: January 30, 2019, 07:31:34 PM »
The factory shop manual calls for lithium grease on the manifolds to cylinder head surfaces. It is sold in auto parts stores under the trade name Lubriplate.
Offline mgmradio
« Reply #9 on: January 30, 2019, 08:47:31 PM »
Don't use RTV , you'd just be asking for a leak. On the metal to metal contact surfaces if there are any leaks they will seal up with carbon.
« Reply #10 on: January 30, 2019, 11:25:02 PM »
I don't want to see the high temp sealer (orange stuff) so I use a pick in case any squeezes out . I do not want to see it. I typically only put a very thing coat . I don't want to take the chance to hear a exhaust leaks which carbon my or may not seal up . It is just a little insurance policy which to others may not think is needed. In my case I don't want to take the chance of a problem and since it is typically invisible with the right effort the detail makes sense to me . Others may think differently .
