Author Topic: 66 hipo pcv valve/grommet  (Read 778 times)
Offline 1966KGT
« on: January 27, 2019, 10:29:08 AM »
im trying to figure out which pcv valve/grommet is correct for my hipo chrome valve covers on my 66 San Jose 11/08/65 GT fastback, using search feature I am thoughrly confused.
« Last Edit: January 27, 2019, 05:03:45 PM by J_Speegle »
1966 K GT, BUILT 11/08/65 4 SPEED, SAN JOSE CAR, 1969 Mustang convertible, 1970 MACH 1, 1963 GALAXIE Q code Fastback, 1966 mustang t code coupe, fuel injected
Offline rrenz
Re: hipo pcv valve/grommet
« Reply #1 on: January 27, 2019, 12:08:32 PM »
Ive asked this question before about my C Code and never got a response. I had bought an original set of 66 valve covers that had a grommet already installed. It actually had a FoMoCo stamping on it. It was of the round variety. There are various different types from suppliers and it certainly makes it confusing.
Ryan
1966 C Code NJ Springtime Yellow
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
« Reply #2 on: January 27, 2019, 12:27:16 PM »
378766-S. Look in the hardware spreadsheets in the library for sources.
« Reply #3 on: January 27, 2019, 12:59:42 PM »
In the MPC this grommet appears to be "dual named".  I see the 378766-S that Jim mentioned, but also C6AZ-6A892-A.  It is interesting that the 3787766-S MPC record has a note that says "also refer to basic no. 6A892".
I hate when the same part has two part numbers  8)
This part is also used on 6 cylinders of the same time period.
The 65 MPC lists the 378766-S for 6 cylinder engines, but no listing found for a V8.
For the 289 HiPo (special) it says "from 5/2/66".  Does anyone know why?  Were there draft tubes before this?
If someone adds a picture or two of an original that will make this thread more valuable in the future.
Also if there are known discrepancies between factory practice and the MPC that would be nice to know.
« Last Edit: January 27, 2019, 01:02:44 PM by 67gta289 »
« Reply #4 on: January 27, 2019, 04:57:00 PM »
The part does NOT have two part numbers, the application has two different parts that will work, assembly line and service.
Not uncommon. No explanation. Future editions do have the info.
If that info is from the MPC, it may be for a different hole in the valve cover. Draft tubes were used in 1964 (my 289 HP Fairlane had one), maybe in early 1965. I think that was addressed on another thread.
There's a drawing in the "Ford Standard and Utility Parts Catalog, 1965" (and 66) page 46 (type 2).
Therein lies the problem. If the MPC agrees with the assembly drawings, you're probably OK. If not, that's part of the function of this forum. Remember - Ford was not building concourse grade cars.
