Author Topic: 69 Boss rebuilt engine complete with June build date  (Read 1599 times)
Offline Keithc8
« on: November 01, 2010, 11:27:44 PM »
 Have a complete numbers matching Boss 302 engine from carburetor to oil pan with the numbers matching exhaust manifolds complete of the dyno and ready to go. this is a complete original engine that is .010 over with original std/std steel correct 69 crank. If you have a late 69 Boss 302 car there is not a nicer engine out there. The intake date is correct, front cover, water pump, damper, heads and all match. Correct valve train complete with restored correct date code J carburetor.
 Engine made about 325 ft/lbs of torque and 350 HP on the dyno with replacement camshaft. Completely balanced and blue printed and ready to go with new AMC engine bolt kit and correct paint. I will sell the complete engine with carb and exhaust for 13,500.00. The carb normally brings in the 1500.00 to 2000.00 range and the exhaust manifolds in the 1000.00 range alone.
 I would also consider a 69 Boss 302 car to purchase that needed restoring that would work with this date code engine.
Thanks, Keith Craft
870-246-7460
