My car has a T-ten B/W transmission with the 4 speed shifter, rods, tabs and Ford shifter with reverse lock out. In a previous discussion I learned that the HEH-BT close ratio trans is the assembly line part correct for my May of 65 San Jose GT. I also learned that the present shifter, rods and tabs would need to be replaced ? Looking for some help with that. My shift lever with reverse lock out finger pull should swap to another shifter body OK ? The Ford shifter bodies usually have no identifying numbers or marks but are all the same up to 68 ? Do the Ford rods and tabs carry any identifying numbers or marks ? Thanks for any help with this. Brian
Brian,I remember the initial thread discussion. I do find it more than a coincidence that two 1965 SJ GT Fastbacks with scheduled build days 14 days apart have identical Borg-Warner transmissions that should have been Ford Toploaders. Maybe this is one for Jeff's San Jose differences list. Jeff or Charles?Steve
Jeff,In Brian's original 2015 thread there was another person, petersixtfive, who posted a pic of the date code for his T-10 from his June 65 SJ GT Fastback. It was a May 25, 1965 shift 1 date. I know this is a VERY small sample and not statistically significant , but all three cars are SJ GT fastbacks. Steve
