Author Topic: 67-Only Red Dye Parts  (Read 367 times)
« on: January 16, 2019, 01:56:14 PM »
I've just spent a few hours going through a number of "Safety Red Dye" posts and it appears that in 1967 the number of places red dye was used is extremely limited.
I see the front turn signal 'wire tie' has a red dyed look.
A replacement long brake line from rear d/b pressure regulator to heater area -- early 67 over the column style brake routing -- has red dye on the front tube nut.
And that's all I've found. Is the brake line correct? Any other uses of red dye on 67 cars?
Re: 67-Only Red Dye Parts
« Reply #1 on: January 16, 2019, 02:59:12 PM »
This is the only thing I can think of, but it is probably more along the lines of a thread locking item than a dye to confirm something was installed and torqued correctly.
http://www.concoursmustang.com/forum/index.php?topic=1096.0
