Author Topic: 1968 Fuel Tank Sending Wire Protector  (Read 2241 times)
Offline Coralsnake
Re: 1968 GT 390 (San Jose) June 5, 1968 Fuel Tank Sending Wire Protector
« Reply #15 on: January 15, 2019, 06:16:21 PM »
Some 1968 Shelbys have the strip, while most do not. None had the convienence group.
« Reply #16 on: January 15, 2019, 09:28:52 PM »
I built a J code HCS a couple of years ago that did not have the convenience light but had the plastic protector. It did however have the sound deadner on the tunnel like a cougar. It makes me think the Mustangs that got them by virtue of random mistakes.
Offline bullitt68
« Reply #17 on: January 15, 2019, 11:44:10 PM »
Very interesting indeed
Mike
Offline bullitt68
« Reply #18 on: January 15, 2019, 11:45:13 PM »
Good to know. Makes sense
Mike
Offline Beeler422
« Reply #19 on: October 17, 2023, 04:57:20 PM »
Admin Note: This reply and the following one were separated from a different thread on another subject and move to this one.
Thanks guys.  That the info I needed.  Rather than start another topic, here's another question.
When I removed my gas tank, there was a piece of plastic that was like a chase that the sender wire ran inside of.  This plastic was held in place by screws on the flanged that hangs down under the gas tank opening.  I can't find this piece anywhere.
Thanks again.
« Last Edit: October 17, 2023, 06:05:58 PM by J_Speegle »
« Reply #20 on: October 17, 2023, 05:19:49 PM »
Thanks again.
Don't really have to start a new thread and bu putting it into this thread it makes it a little more difficult for the next guy with the same question to find your question and the responses. There is a whole thread on the subject but as a quick direct response to "I can't find this piece anywhere.  " if you referring to a source for these that you can just find on a web page or catalog you won't. Don't think they have ever been reproduced nor given the limited usage of them likely ever will be. Got to find a good original
Will find the main thread and merge your question over there
« Last Edit: October 17, 2023, 06:06:10 PM by J_Speegle »
Offline Keith Stem
Re: 1968 Fuel Tank Sending Wire Protector
« Reply #21 on: October 17, 2023, 07:06:53 PM »
I have one on my 5/1/68 Dearborn CJ, it does not have the convenience group option.
Offline bullitt68
« Reply #22 on: October 31, 2023, 04:16:13 AM »
I wonder if the "Convenience Group" plays into the use of the plastic protector in 68 cars. Just as a possibility of why some have and others do not. ALL 68 XR7's have Convenience group so this may explain seeing them on Cougars.
Yes that is a good point. I am going to see if I can track one down at WCCC
Mike
Offline bullitt68
« Reply #23 on: October 31, 2023, 08:46:38 PM »
I found this on the WCCC website, but they don'y have any in stock. Now I know what I am looking for. Hopefully one turns up eventually
Mike
« Reply #24 on: October 31, 2023, 09:21:53 PM »
Don't be surprised to find most are deformed and distorted. They are mounted 1/4 to 1/2 from mufflers  on most applications. Given the close proximity to the muffler they are victims of the heat.
Offline bullitt68
« Reply #25 on: October 31, 2023, 10:53:52 PM »
Well that explains why you never see one other than the remnants left behind. Hopefully I find one, but I am not holding my breath
Mike
« Reply #26 on: October 31, 2023, 11:36:15 PM »
On a 1968 Cougar there is a better chance at finding one that is not so melty. No transverse mufflers on 1968 and newer Cougars.
We don't find them very often either.
Offline bullitt68
« Reply #27 on: October 31, 2023, 11:54:08 PM »
I didn't think so. But I will keep looking
Mike
