Author Topic: Console Wiring Clips  (Read 855 times)
Offline SunnDogg
« on: January 10, 2019, 07:00:04 PM »
Has anyone found a vendor or have a part number for the wiring loom clips that are used (4) on the floor console? Picture of said clip attached. Thanks in advance.
Re: Console Wiring Clips
« Reply #1 on: January 10, 2019, 08:16:53 PM »
If I may direct your attention to this forum's library section under topic "Mustang Hardware Spreadsheets 69-70" where you will find two spreadsheet files, one by part number and the other by application. Under application, "Wiring Harn, Console, Center-Console", you will find part of your answer.
« Reply #2 on: January 10, 2019, 10:49:57 PM »
Don't believe they are reproduced and will be difficult to find ( I would guess) as NOS)
Likely a used part that you'll need to get from a donor
Offline SunnDogg
« Reply #3 on: January 11, 2019, 01:15:31 PM »
Thank you, both. Was not aware of the spreadsheet in the library. Appreciate the help.
Offline 7Lscjracer
« Reply #4 on: January 15, 2019, 09:18:48 PM »
What size are the clips you need and full or partial loop?
Bought May '81, sold Sept '20
