Author Topic: Original starter cable shielding  (Read 1140 times)
Offline 68 S Code
« on: October 31, 2010, 05:19:21 PM »
I have my original starter cable and would like to re-use it but the cloth like shielding is junk. I know someone who has oem shielding but I can't see how to go about installing it . It almost looks like it would have been installed prior to molding one of the end connections. It seems impossible to reinstall without cutting the cable in two. Well I won't do that. Is there a trick to doing this? The shielding is just a touch bigger in id than the cable and much smaller than the molded rubber and metal end.
Re: Original starter cable shielding
« Reply #1 on: October 31, 2010, 09:47:20 PM »
I've been investigating cloth weaving for my harness restoration business, and yes, it appears you are correct: the weaving is applied before the ends are molded/crimped.
I believe there may be a couple of companies that will actually weave something onto an existing wire: try http://www.riwire.com/
Offline 68 S Code
« Reply #2 on: November 01, 2010, 12:00:23 AM »
Thank you for the lead. I will contact them to see what they suggest or can do.
