Author Topic: 66 Upper Control Arm Nuts  (Read 854 times)
Offline rrenz
« on: January 04, 2019, 06:45:49 PM »
The Hardware spreadsheet seems to have 3 different fasteners listed. Trying to determine if my car still retains the original hardware. Stripped paint off of my existing nuts and wanted to re- phosphate them. The ones I have appear to be zinc plated. Are there different variations? These are the bolts that attach to the shock tower in the engine compartment.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
Re: 66 Upper Control Arm Nuts
« Reply #1 on: January 04, 2019, 07:08:16 PM »
I see only two, 378290-S8 1/2-20 hex, GR8,  from the 64-66 Mustang Chassis Manual, and 380952-S 1/2-13 hex, GR8, used as a service replacement with the service replacement arm and/or shaft assembly. Note the difference in threads.
« Reply #2 on: January 05, 2019, 04:20:26 PM »
I've only seen zinc or cad on upper control arm locking nuts on 65-66.
Offline rrenz
« Reply #3 on: January 05, 2019, 06:41:44 PM »
Amk sells a bolt that appears to be a very dark zinc/phosphate looking bolt. This is what caused my confusion. Just trying to get the finish right.
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #4 on: January 05, 2019, 07:55:34 PM »
A zinc plated nut on a phosphated bolt is normal, if that is your concern.
« Reply #5 on: January 05, 2019, 10:27:35 PM »
Believe the bolts were likely heat treated but the important thing is the final look for our purposes so P & O or other process's will do the trick
Offline rrenz
« Reply #6 on: January 08, 2019, 12:39:43 PM »
I was starting to wonder if it was heat treated. The solves my concern. Thanks.
Ryan
C-4 Automatic
Build Date Jan 21st
« Reply #7 on: January 08, 2019, 02:05:47 PM »
Phosphating that specific heat treated bolt, or any other heat treated item, will not affect its hardness. The phosphating process uses water under 212F, aka boiling. It takes a lot higher temperature to affect heat treated items.
