One could probably type a paragraph on each of those items and not approach the knowledge that you could have by just searching this site and looking at all that has been displayed in photos and words. You are going to have to search using the proper spelling, much of what you typed has grammatical errors which will cause you to not find anything useful. For example spindal is an error, calliper etc. Spell check is your friend.
I have updated the list with what I was able to deduce, but more confirmation is required. I have been thrown off by mistakenly referencing Shelbys. Please advise if there are any glaring errors.
Lower Control Arms (Unpainted Ends & Black Dipped)
Upper Control Arms (Unpainted)
Upper Control Arm Shaft/Bolt (Phosphate)
Upper Control Arm Shaft/Bolt Nuts (Silver Zinc)
Upper Control Arm Nuts Through Apron (Silver Zinc)
Coil Springs (Gloss Black with Yellow Green Paint daubs)
Strut Rods (Unpainted)
Strut Rod Rubber Bushing Large Washers (Silver Zinc)
Strut Rod Rubber Bushing Nuts (Red, Purple or green Silver Zinc))
Strut Rod Nuts at Control Arm (Silver Zinc)
Upper Ball Joints (Bare Metal)
Upper Ball Joint Nuts (Gold Cad)
Lower Ball Joints (Unpainted)
Lower Ball Joint Nuts (Gold Cad)
Ball Joint Rivets (Silver Zinc)
Spindle (Unpainted)
Spindle Cap (Unpaintedl)
Spindle Nut (Silver Zinc)
Rotor Backing Plates (Semi Gloss Black)
Callipers (Bare Metal)
Caliper Clips (Silver Zinc)
Caliper Cover (Silver Zinc)
Shocks (Semi Gloss Black)
Shock Nuts (Silver Zinc)
Shock Absorber Bracket (Phosphate or Semi Gloss Black)
Upper Control Arm Coil Spring Seat/Perch (Unpaintedl)
Upper Control Arm Nuts & Washers (Silver Zinc)
Lower Control Arm Bolts, Washers (Silver Zinc)
Brake Rotors (Silver Zinc)
Leaf Springs (Unpaintedl)
Leaf Spring Shackles (Unpainted)
Shackle Bolts (Phosphate)
Shackle Nuts (Silver Zinc)
Leaf Spring Bucket Bolts (Phosphate)
Leaf Spring Bucket Nuts (Silver Zinc)
Leaf Spring Banding (Unpainted)
Shock Nuts Upper (Silver Zinc)
Shock Washers Upper
Shock Nuts Lower (Silver Zinc)
Shock Washers Lower
Lower Shock Plates (Bare Metal)
Rear Brake Line Junction Block (Yellow Brass)
Rear Brake Drums (Unpainted)
Axle Lug Nuts (Unpainted)
