Author Topic: Heater Resistor switch  (Read 1722 times)
Offline sparky65
« on: October 29, 2010, 05:46:25 PM »
Is there a way to remove and reinstall the heater resistor switch from the heater case?  the original switch in my busted up case looks nicer and I would like to swap it but I don't see how I can save the plastic clips that hold it in place.
Steve
2009 Black GT Coupe
Offline Twilight65
  • Gold Level Subscriber
Re: Heater Resistor switch
« Reply #1 on: October 29, 2010, 07:16:51 PM »
You can drill out and replace the plastic rivets. Here's a link to a previous thread.
http://www.concoursmustang.com/forum/index.php?topic=798.msg4089#msg4089
« Reply #2 on: October 30, 2010, 01:05:12 AM »
The plastic pins can be pushed out from the back side and re-used.
Offline sparky65
« Reply #3 on: October 30, 2010, 03:52:55 PM »
Thanks Charles.  I had tried that but couldn't get them to move.  I just soaked them with WD-40 and then I was able to get them out.
Steve
2009 Black GT Coupe
« Reply #4 on: October 31, 2010, 01:40:14 PM »
Small tip screwdriver and a rubber mallet usually works.
