Author Topic: FS: Used Mustang Parts -- Various Years (mostly 65-70)  (Read 2599 times)
« on: December 29, 2018, 06:53:12 PM »
I will add/delete from this list as parts are sold and pulled from the storeroom. I will pull items from my other lists and put them into this one in order to simplify things. Those other ads will be locked so all ads will appear here.
All are OBO, Papal F&F, PLUS postage.
* 70 Boss 302 'Alternate' Water Pump Pulley for P/S $49.95
D1AE--8509-BA Not stock for B302 but will work as a replacement for the C90E-8509-G
* 65 V8 Front Coil Springs
Buy these before I decide to cut them up so I can get the upper arms out easier. $35 ea.
* 68 14x5 wheel 7MM (Decode: Motor Wheel Dec 67) $35
https://photos.app.goo.gl/YivT8vQvLFbrLxF96
* Dagenham 4 speed shift levers "O L" and "O R". Both for $50
http://www.concoursmustang.com/forum/index.php?action=dlattach;topic=20223.0;attach=56033;image
* Linkage for above, $75 or $100 for all linkage and levers
http://www.concoursmustang.com/forum/index.php?action=dlattach;topic=20223.0;attach=56035;image
* C8AE-J water pump. A reasonable core to have rebuilt. See pics. $50 OBO
https://photos.app.goo.gl/TdgpBdjeMZD8dH9s9
* 68 Mustang and Cougar No-Vent disc brake shields. West Coast Cougar has one: https://secure.cougarpartscatalog.com/c8oz-2k004-a.html?attribs=76
but one of mine has much fewer pits and the other has much, much fewer pits.
These come with the inner grease shield as well. All are rectangular FoMoCo marked. Before SEM semi-gloss these were glass beaded (the round beads, not the cutting action). $300 250 pair. if you need the matching C brackets add $200 175 or "Let's Make a Deal" on both. Or trade for 67 Shelby parts. Prefer the later!
I know Fuller has his repop shields, so I will consider offers.
https://photos.app.goo.gl/ygsrfkVbW3HHnxPMA
* 68 (after 2/68) rear side reflectors -- New, but no gaskets!
NPD part 13380-1A. BOTH for $45.
* 65 SJ-only 'raised dot' firewall pad clutch rod cutout. This is the piece you need if yours falls out. $50 OBO
* FT/LR8 Shelby/CS Style Lucas Light -- Not original glass lamp or wire. Housing in good nick, but has large wire grommet. $150 125
https://photos.app.goo.gl/qhtEDRYhuZ3e1hjk9
* Early  70 D0OE-C 351W heads -- appear unmolested and still have valves, springs and rockers (rail). Previous listing said 69! It was a long day ...
Head one: D0OE-C 9D24 cast #18 on exterior visible surface.
Head two: D0OE-C 9E2   cast #5 on exterior visible surface.
Square FoMoCo casting. $200/pair OBO and then figure out how to ship these.
*67/8 Transmission Selector Rod C4 Trans. This is the selector rod (PRND...) for the C4 trans. C7ZA-7326-B stamped in rod. Nice shape and includes correct wave washer and clip. $30 OBO
   https://photos.app.goo.gl/129WKUWrTV7sXv9B8
   https://photos.app.goo.gl/VrFJ7eXa2xoqnHHx9
 * I have the selector box too. Chrome looked good when I glanced at it. $20
* 69 Mustang ash tray mount, ash tray and light holder. Includes slide in ashtray with knob. Ashtray bin was a bit rusty, but has been media blasted on the interior only to make sure rust didn't go all the way through.
Driver quality on ash bin. Rest is nice. $90 obo.See pics here:
https://photos.app.goo.gl/5UtDPZvTPMj9behJA
*68 Coupe Glass -- All Sun X
 68 Coupe Rear Glass -- Sun X tinted M61; date coded 8B
 68 Coupe Right Door Glass -- Sun X tinted M61; date coded 8A
 68 Coupe Left Door Glass -- Sun X tinted M61; date coded 8B
$60 each OBO. Better deal on all three. I also have an 8C windshield, same specs, but it has a divot on the passenger side.
* 66 Mustang SunX LH Side Vent Window (glass only) Carlite FM-M31 Dtd 5L $20
* C9ZZ-1130-D Shelby Wheel Cap (one only); in the box. $40 Here are a few shots:
https://photos.app.goo.gl/qnN3Izqxfopexyb73
https://photos.app.goo.gl/ME2fMCJ9zfgD24Pj1
https://photos.app.goo.gl/vw7vBsQTPLKUEUUv2
* 84 SVO Lower Control Arm (right). Missing inner bushings -- shells still there. BJ is there, boot is missing. All other components present. $50 OBO.
* SVO E45C-AA USED Rotors -- 2 Front. These are USED 5 bolt original issue front rotors. No grooves. $20 ea.
* C6DF-14431-A "WCC" Starter to Solenoid Cable; Excellent non-SJ car cable.
Cable is 30" long and is for 6 cyl according to the 60-68 MPC  $25
https://photos.app.goo.gl/R62jyh1Ex3bWL62ZA
PM or email bossbill [the at sign] comcast [add dot net]
PayPal Friends and Family plus the ride on ALL parts.
To text, try 4two5-five2nine-eight8two9 -- include concoursmustang as your first words.
« Last Edit: December 15, 2021, 12:28:50 PM by Bossbill »
Re: FS: Used Mustang Parts -- Various Years (mostly 65-70)
« Reply #1 on: February 13, 2020, 05:43:45 PM »
Add the B302 non-assembly line water pump pulley
