Author Topic: Drag Pack Oil Cooler Lines  (Read 1829 times)
Offline 1970 Snake
« on: December 24, 2018, 06:04:24 PM »
Would anyone have decent pictures of the actual routing of the drag pack oil cooler lines around the area of the power steering oil cooler on a 428 SCJ Mach 1 1970 mustang. This area seems very tight and congested for the DP oil cooler lines and a PS oil cooler mounted.
« Last Edit: December 24, 2018, 06:53:12 PM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Offline MikeBCR
Re: Drag Pack Oil Cooler Lines
« Reply #1 on: February 12, 2020, 12:52:53 PM »
BUMP
Offline 1970 Snake
« Reply #2 on: February 12, 2020, 01:38:14 PM »
what does that mean?
« Reply #3 on: February 12, 2020, 02:00:12 PM »
moves the thread back to the top of the unread list.
Offline rockhouse66
« Reply #4 on: February 12, 2020, 02:19:33 PM »
The cooler lines are below the PS pump though the PS cooler plumbing sort of mixes in.  I don't have a picture but this diagram is a start.
'66 GT FB
Offline 1970 Snake
« Reply #5 on: February 12, 2020, 02:27:04 PM »
Thanks, much appreciated, have seen this before and it seems to be a typical for the drag pack install.
I was hoping for some actual pics, as I am still working on and mocking up the install on my restoration project.
Offline Mike_B_SVT
« Reply #6 on: February 24, 2020, 09:32:26 PM »
Not a picture from my car, but this is also what mine look like.  Yes, it's very tight in there.
Mike B.
1 of 354 in Sonic Blue
Cat Bites Man!
« Reply #7 on: February 24, 2020, 10:52:32 PM »
From my 69.  I don't have PS.  So no help with that set-up.  Brian
Offline 1970 Snake
« Reply #8 on: February 25, 2020, 01:34:10 AM »
Thanks so much for the pictures guys, just what I was looking for. Yes I thought it would be mighty tight in that area with the PS cooler, washer container, fuel pump and other things. This will definitely help me in the routing of the lines and understanding what goes over and under and where. I appreciate you getting back to me after all this time, as my original post asking for info was back in Dec. 2018.
« Reply #9 on: February 25, 2020, 11:11:02 AM »
428 cobrajet forum   Another resource available to you.  Brian
Offline 1970 Snake
« Reply #10 on: February 25, 2020, 01:01:36 PM »
Do you mean the Cobrajet Registry forum?
Offline 1970 Snake
« Reply #12 on: February 25, 2020, 05:04:38 PM »
Thanks Brian
Offline MorganLeBlanc
« Reply #13 on: February 28, 2020, 12:54:54 PM »
Is there anyone that reproduces the parts to install a Drag Pack Oil Cooler?
Morgan LeBlanc
1969 Mustang Mach 1 S-Code Black Jade
Shelby 427 Cobra CSX4766
Fresno CA
Offline rockhouse66
« Reply #14 on: February 29, 2020, 03:20:21 PM »
The brackets, correct bracket fasteners and the oil cooler are all currently reproduced.  There is also a repro of the oil filter adapter for this setup, though it isn't quite correct.  The oil cooler lines were reproduced, but perhaps not now?
'66 GT FB
