Author Topic: 1970 Bendix Brake Booster  (Read 723 times)
Offline 1970 Snake
« on: December 24, 2018, 03:11:42 PM »
Question, did all the Bendix brake boosters on the 1970 mustangs have Bendix and a date code stamped into the booster housing?
« Last Edit: December 24, 2018, 05:57:03 PM by 1970 Snake »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: 1970 Bendix Brake Booster
« Reply #1 on: December 25, 2018, 10:06:41 PM »
Can't report that "all" came that way, though I think its very likely they did
Did go through my pictures and found a few dozen 70 Dearborn P/Disc Brake applications with the raised BENDIX printing as your example shows
Offline 1970 Snake
« Reply #2 on: December 26, 2018, 01:25:37 PM »
Thanks Jeff, I suspected as you have indicated. I had purchased some time back an SD remanufactured unit and although it looks pretty much identical to my original Bendix it does not have any of the stamped markings and therefore must be a repop and not a remanufactured unit.
