Author Topic: 1970 Mach 1 351 C valve cover engine code  (Read 993 times)
Offline Cobrajetken
« on: December 17, 2018, 11:01:25 PM »
Can anyone help me determine the correct coding for the valve cover decal on a 1970 Mach 1 Mustang 351 Cleveland 4V , automatic, non ram air, non shaker. Thanks. Ken
Re: 1970 Mach 1 351 C valve cover engine code
« Reply #1 on: December 18, 2018, 12:15:56 AM »
Welcome to the forum.
The information you are looking for is referenced in the Ford Car Parts manual which you can download from this site:
http://squarebirds.org/Manuals/1965/1965-72FordPartsTextCatalog/
It's in the text section on engines.
Offline cobrajet_carl
« Reply #2 on: December 19, 2018, 11:02:54 AM »
Build sheet, the original metal tag. Failing that a deluxe Marti might help with figuring it out.  ECS doesn't list that application but I think they could make one if they knew the options and build date. Base code number could be K609A. Did you mean non A/C, non shaker?
« Last Edit: February 07, 2019, 03:27:45 PM by cobrajet_carl »
Carl
70 and 71 Dearborn mach Is
« Reply #3 on: December 19, 2018, 12:03:56 PM »
Kevin Marti's tag book shows 608 for 1970 M code with manual transmission.
« Reply #4 on: December 20, 2018, 01:30:44 AM »
Hi Ken welcome to the site - hope you find the help, information and support your looking for related to your concours related endeavors
Currently on my laptop so screen is too small to read all the right boxes in a buildsheet to figure out the correct codes for your application but will get to it. Don't think I can supply the rest of the codes (plant and timing I believe) since I don't have a bunch of original labels. Most often hidden behind AC pumps or did live almost 50 years
Will report back
Offline 70cj428
« Reply #5 on: December 25, 2018, 09:02:34 AM »
My M code, Auto, Non Ram Air, Non Cali. emissions, with AC Mach1 has K609AG on the build sheet and on the original engine tag, I'm almost certain that the Non Air version of the same car would be the same code without the "G" on the end...
Hope this helps, John
