Author Topic: 1970 bolt in glass qtr window trim weatherstrip.  (Read 734 times)
Offline MikeG69
« on: December 16, 2018, 04:48:43 PM »
I am converting my 69 Coupe glue in glass to the 1970 bolt in style & I need some help. I am trying to replace the weatherstrip in the trim that is on the front of the rear quarter glass that seals to the door window. The replacement w/s part #- D1ZZ-6530147-O. I can not figure out how to remove the old w/s without damaging the the stainless steel trim pieces
Direct Link
« Last Edit: December 16, 2018, 04:50:57 PM by MikeG69 »
I have been involved in Mustangs & working on cars for over 45 years.
1969 Mustang Coupe, 9T01F142xxx, assembled in NJ 11/26/68, 302, auto, meadowlark yellow. (project)
2021 Bronco Sport (Wife's DD)
2005 F150 2WD Regular Cab (My DD)
1999 Explorer Sport (Spare)
MCA #-4549
Offline 69GT350H
Re: 1970 bolt in glass qtr window trim weatherstrip.
« Reply #1 on: December 16, 2018, 08:41:56 PM »
After a long time setting and then recently moving my glass around, both of mine broke at the welds. Bought Repros from NPD. Now I need to carefully remove the smaller part on the glass. Going to start with a plastic pry and use as a chisel to see if I can tap them off. If not I will have to go to something more solid like a real punch/chisel. I'll be using my plastic ended hammer as well.
« Reply #2 on: December 17, 2018, 01:04:30 PM »
Direct Link
Remove the Phillips head screw. Use a vise and clamp part of the rubber, pull on the moulding, It just slides out. Some can be kind of stuck, but I have always been able to get them to separate. Maybe a little twisting while pulling.
Offline MikeG69
« Reply #3 on: December 17, 2018, 03:43:04 PM »
Thanks, I will give that a try.
MCA #-4549
Offline MikeG69
« Reply #4 on: December 19, 2018, 09:15:08 PM »
Update; I tried what you suggested & some twisting & prying I got the weatherstrip out of the trim piece, of course the second one came out very easy. Thanks again for your suggestion.
MCA #-4549
