Author Topic: Front Bumper Brackets - Outer Arm Insulators  (Read 793 times)
Offline 1970 Snake
« on: December 15, 2018, 02:21:42 PM »
Can anyone clarify what type of hose Ford used on the front bumper struts to protect them from marking and rattling in the opening on the front valance of a 1970 mustang.
I thought they where heater hose but it does not look that way as the heater hose has reinforcement in the rubber where the strut protectors do not, although they do seem to have the same strips molded into them as the heater hose, but the heater hose has a smaller bore and thicker wall.
« Last Edit: December 15, 2018, 10:52:26 PM by J_Speegle »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Front Bumper Brackets - Outer Arm Insulators
« Reply #1 on: December 15, 2018, 02:31:35 PM »
I have found that the drain hose from the earlier years fastback vent assemblys is a thin wall design almost identical.
« Last Edit: December 15, 2018, 10:52:42 PM by J_Speegle »
Offline 1970 Snake
« Reply #2 on: December 15, 2018, 03:39:17 PM »
Thanks Bob, which drain hose as I am not familiar with that item, can I look it up somewhere or do you have a picture?
« Last Edit: December 15, 2018, 10:52:49 PM by J_Speegle »
« Reply #3 on: December 15, 2018, 04:06:26 PM »
Here is a ebay auction showing one .https://www.ebay.com/itm/1965-1966-1967-1968-Mustang-GT-Shelby-ORIG-FASTBACK-QUARTER-VENT-DRAIN-TUBE-HOSE/162387275994
« Last Edit: December 15, 2018, 10:52:57 PM by J_Speegle »
« Reply #4 on: December 15, 2018, 07:48:29 PM »
Looking at all the years they used these insulators have seen a number of different supplier markings and even shapes though the round versions appear to be the vast majority. As Bob mentioned the 65 unreinforced fastback quarter vent drains  but those can be more difficult to find than just original used ones from another 69 or 70. Believe they are both the same length though must admit that I've never compared the two side by side.
Just have to find someone that took the time to remove and same a couple since these are big movers/sellers and often get over looked.
« Last Edit: December 15, 2018, 10:53:05 PM by J_Speegle »
« Reply #5 on: December 15, 2018, 10:13:59 PM »
Would this 'front bumper strut' also be called an 'outer arm' ?  Thanks, Brian
« Last Edit: December 15, 2018, 10:53:13 PM by J_Speegle »
« Reply #6 on: December 15, 2018, 10:54:28 PM »
Guess some (especially some engineers) might take issue with the use of strut so adjusted the title so it reflects that the discussion is about the insulator with a slight adjustment to the other words.
