Author Topic: 70 Engine Compartment Main Wiring Harness  (Read 1004 times)
Offline 1970 Snake
« on: December 07, 2018, 01:12:08 PM »
I am in the process of restoring my main wiring harness in the engine compartment and have a broken mounting clip. There are two types of mounting clips taped into the harness and it looks like the one (pic 7121) is a specialty clip that is stapled to a plastic strip which is taped into the harness. Are these specialty clips reproduced or do I need to find another harness and rob the clip and/or entire strip and clips??
« Last Edit: December 07, 2018, 07:18:12 PM by J_Speegle »
Dearborn Built Sept 4, 1969
1970 Mach1 428 CJ R-Code C6
dash tach, front bumperettes
Re: Engine Compartment Main Wiring Harness
« Reply #1 on: December 07, 2018, 01:52:14 PM »
amk book
« Reply #2 on: December 07, 2018, 03:30:56 PM »
amk book
Could you be a bit more specific (page, part number, etc)?
Offline 1970 Snake
« Reply #3 on: December 07, 2018, 04:32:45 PM »
I have looked at the AMK catalog and could NOT find these, but they did have something close to the other plastic one with the barbs.
« Reply #4 on: December 07, 2018, 06:10:13 PM »
b-10976  page 159 yellow cover book   just take off the  foam washer
Offline 1970 Snake
Re: 70 Engine Compartment Main Wiring Harness
« Reply #5 on: December 07, 2018, 07:25:15 PM »
Okay great will get the AMK ones and remove the foam washer. I am assuming the stapling to the plastic strip was to get the retainer clip spacing right during wire harness fabrication at the vendors.
