Author Topic: Identifying Small and Large Bearing Ford A/C Pulleys 1968-73  (Read 1175 times)
« on: December 06, 2018, 10:01:27 PM »
Many times the large and small bearing difference does not come into play. However, starting in 1970, Ford went to a larger diameter bearing on their air conditioning pulleys, both fixed and adjustable. Most of the 1970 and later pulley assemblies for A/C have a casting number stamped onto the brackets.
The adjustable pulley is easy, 1968-69 versions do not have a stamped casting number and uses the small bearing for the pulley.
Starting in 1970, that adjustable pulley was stamped D0AA-8A617-_, Ford also used 2 different pulleys, a one piece design, and a two piece design. Have also found several different dust caps for the bearing too.
Picture shows both versions of the adjustable pulley, the large bearing on the left, shown with a nickel, small bearing pulley on right with a quarter.
Re: Identifying Small and Large Bearing Ford A/C Pulleys 1968-73
« Reply #1 on: December 06, 2018, 10:19:39 PM »
The 390 and 428CJ version of the Ford fixed idler pulley from 1968-69 has a small bearing, Ford part number C8AZ-8678-B, but not stamped with a casting number like the small block versions. Photo provided, with permission, by Bob Gaines.
The FE version of the Ford fixed idler pulley starting in 1970, has a Ford part number of D0AZ-8678-D (also without a casting stamp) and got a larger bearing for the pulley. The other photo shows the two piece pulley design, there is also a one piece version of the pulley.
Unfortunately the pulleys are not interchangeable on the two different brackets. The shaft is a different diameter for small and large bearings. About 0.596" inside diameter on the small bearing, and about 0.674 for the inside diameter on the larger bearing.
Offline 70cj428
« Reply #2 on: December 13, 2018, 07:59:11 PM »
Hi Scott, got a question,
I have an August, 1969 Dated NOS engine side AC kit I was going to use for my 70 CJ AC car. The fixed Idler bracket is present but it doesn't have a pulley or bearing, just the hole where they mount, and the instructions enclosed show the bracket with no pulley. Is this a 69 vs 70 thing or something else.. The kit was intended for 1969 390 Mustangs .....  ( I was told ther was no kit available for 428 cars ...)
« Reply #3 on: December 13, 2018, 08:30:42 PM »
Not Scott but It is the same bracket regardless of if 390 or 428. Yes it is meant to have a pulley on the fixed bracket. I have had a lot of those kits over the years and the all typically had just the bracket with no pulley . You can find a more common adjustable pulley and then press out the pulley and bearing. You re use the pulley and bearing to install in your bare plate.
