Author Topic: 67 Glovebox Clip Rivets  (Read 961 times)
« on: December 05, 2018, 07:24:27 PM »
I suppose it has gotten down to this level of minutia.
Are the rivets that hold the owner's card (my guess) clip black or silver colored?
They are steel so if silver I can't tell if they are natural, zinc or Cad?
Or were they painted black to meld in?
« Last Edit: December 06, 2018, 02:47:35 AM by Bossbill »
Re: 67 Glovebox Clip Rivets
« Reply #1 on: December 06, 2018, 12:38:11 AM »
What I've had to do a few times is "remove" a rivet to see what color is on the underside of the head and shaft. In Hi-Tech, it is referred to as destructive analysis.
Offline bullitt68
« Reply #2 on: December 06, 2018, 01:32:57 AM »
I am glad you posted that as I was going to ask the same question. I will check my glove box and see if I can gather any intel and report back
Mike
« Reply #3 on: December 06, 2018, 02:56:26 AM »
I was hoping to not remove it. Get a Dremel and clean it up or some evaporust or both.
Then paint with black or silver.
I have an ugly spare, though.
Ok, I'll take that one apart.
Bullitt68 -- I wasn't sure if 68s still had the plate. Be interesting to hear back.
« Last Edit: December 06, 2018, 03:00:55 AM by Bossbill »
Offline bullitt68
« Reply #4 on: December 12, 2018, 04:36:07 AM »
Hi Bill sorry for the late replay but here are my glovebox door rivets. Unfortunately mine look just like yours and judging by how out both rusted I am going to dare to assume that they were not painted, or plated, but bare metal, which would explain the rust on both sides. Some of the only rust I have found on my car. Also it would appear that the clip is either painted or phosphated. Your clip looks to be in better shape than mine. I thought that mine was actually unpainted until I saw yours. I assumed that mine was just weathered due to age.
« Last Edit: December 12, 2018, 04:40:23 AM by bullitt68 »
Mike
« Reply #5 on: December 12, 2018, 11:15:27 AM »
I usually soak the whole liner in evaporust.  Just have to be sure to rinse well an blow out with compressed air.  Follow with metal protectant.
Offline bullitt68
« Reply #6 on: December 12, 2018, 12:56:15 PM »
Great idea. Then do you paint the clip?
Mike
« Reply #7 on: December 12, 2018, 02:28:06 PM »
It was plated I believe so no I would not
« Reply #8 on: December 12, 2018, 02:47:43 PM »
Thanks for the followup pictures, Bullitt68.
My clip appears to have a decent finish (of some sort) so I too will Evaporust the whole thing and then protect the rivet finish on both sides.
The staples should also look minty fresh.
Offline bullitt68
« Reply #9 on: December 13, 2018, 07:55:35 PM »
Good idea Bill. I am going to drop my glove box in Evaporust tonight and leave it overnight and see how it turns out. I do love evaporust. Hopefully it will not affect the plastic in anyway. Normally it does not.
Mike
Offline bullitt68
« Reply #10 on: December 19, 2018, 04:26:41 AM »
Hi Bill. Sorry for the slow reply. I soaked the glove box in Evaporust and this is how it turned out. Did you do yours yet? I don't think I need to do anything else. I am not sure how the clip looked it originally.
Mike
« Reply #11 on: December 19, 2018, 02:11:17 PM »
Pic one uses a flash.
Pic two shows how it looks in ambient light.
Pic three is the back side.
I suppose the true test is how it would look with a glovebox light shining on it.
There is some light exterior paint fog on the top, back side of the liner which I elected to leave.
Interesting that it managed to find its way back there.
I think the rivet has a light cad (or similar) applied to it, so the rivet is shiny.
Neat topic that never comes up. Thanks for sharing.
Offline bullitt68
« Reply #12 on: December 19, 2018, 02:19:08 PM »
Looks good Bill. I May stelel wool the rivets a bit, but other than that I think this is a great example of when Evaporust is the ideal product. It works great on parts you cant either disassemble or treat with other methods. Of course one could remove the rivets, but for correctness this is a better option IMO. Thanks for pointing that out.
Mike
