Author Topic: hood pin finish for cheep..  (Read 2737 times)
« on: October 25, 2010, 03:32:11 PM »
65 hood pin. should be gold zinc chromate. anyone know of an inexpensive way to replicate without using paint? are there any dyes available that would suffice? don't want to have to send it off and don't want to buy a plating kit either.....ideas?? yeah, i know i'm being a tightwad today.
Offline sdgrant
Re: hood pin finish for cheep..
« Reply #1 on: October 25, 2010, 04:46:45 PM »
I'm sure it varies, but I just had mine replated for $10 about 18 mo. ago.  No other pieces for a volume discount, either!
Steve Grant
MCA Certified Judge, '64½ - '66 class
1964½ Mustang Indianapolis 500 Pace Car coupe
« Reply #2 on: October 25, 2010, 05:25:19 PM »
whose services did you use?
« Reply #3 on: October 25, 2010, 10:12:58 PM »
You can dye it (the dichromate is just a dye used after the zinc plating) but the dye does not look great by itself - without the underlying base. And the dye will cost $25 (or so) or more
Offline C5ZZKGT
  • Gold Level Subscriber
« Reply #4 on: November 03, 2010, 05:33:33 PM »
May I jump in for a minute and ask what finish the "other" part right next to the pin is supoest to be finished in??-same as the pin??
« Reply #5 on: November 03, 2010, 06:07:23 PM »
If you're referring to the safety catch, it should be phosphate/oil.
Offline C5ZZKGT
« Reply #6 on: November 12, 2010, 10:54:22 AM »
Thanks Charles, Yep, its the safety catch I just couldn't remember what it was called....so IT needs to be Phosphate & Oil and the pin itself needs to be Zinc DiChromate then......
« Reply #7 on: November 13, 2010, 04:36:23 PM »
well i tried something today.....what's your opinions ?? i lightly blasted the hood pin @ 60 psi using fine glass beads. wiped it down with 000 steel wool & lacquer thinner. then i used some rit yellow gold dye. about a teaspoon full in a pan 1/2 full with 160* water. i soaked it for about 5-7 minutes then rinsed it with cold water. the dye package cost $2.49......attached are the results..........
« Last Edit: November 13, 2010, 05:03:19 PM by carlite65 »
« Reply #8 on: November 13, 2010, 06:30:12 PM »
Looks decent Fred, hard to tell from pics though.
Offline Richard P.
« Reply #9 on: November 13, 2010, 08:55:40 PM »
+ 1 Fred
