Author Topic: 64.5 V8 screw together fuel pump rebuild kit  (Read 542 times)
« on: December 02, 2018, 09:41:22 PM »
Does anyone know where to obtain the correct rebuild kit for a 64.5 260 V8 with screw together fuel pump?
Re: 64.5 V8 screw together fuel pump rebuild kit
« Reply #1 on: December 02, 2018, 10:20:02 PM »
Charles, everyone I know uses the one AMK makes which is available from Virginia and NPD. It is typically associated with the later Carter pumps but apparently the parts interchange satisfactorily because I haven't heard of a issue.
Offline michaelvonlanthen
« Reply #2 on: December 03, 2018, 11:42:40 AM »
I have a NOS 64.5 V8 fuel pump repair kit with box.
Michael Vonlanthen
Switzerland
5F08D189*** - 76A   F   42   06G    75   1   6
Guardsman Blue Convertible with white interior, AT, PB, AC, console, Rally-Pac
Offline FXguy
    • Early 64 June K Convertible Restoration
« Reply #3 on: December 03, 2018, 07:55:28 PM »
I used the later kit from VCM on a 64.5 K pump and it went together fine, though I have not run tested it, yet.
-Scott
Scott McMullen
64 1/2 K Code Specialist, pre/early production historian, collector, and restorer.
"I'm absolutely sure of one thing, and that is I don't know everything...there is always something new to be discovered...and that's where the fun is."
« Reply #4 on: December 04, 2018, 01:42:14 AM »
Thanks for the replies.  I have a spare kit from AMK, so will go ahead and use that.
