Author Topic: 1968 GT 390 Heater Motor Verification (Correct Paint Finish)  (Read 1025 times)
Offline bullitt68
« on: December 01, 2018, 10:00:41 PM »
Just curious if this is an original motor or not, The sticker/decal leads me to believe that it has been rebuilt. I just want to make sure before I remove it and paint it. Also what level of gloss should it be. I was planning to paint it semi gloss, close to what it is now. Also curious if it should be the same gloss as the firewall or slightly glossier.
Mike
Re: 1968 GT 390 Heater Motor Verification (Correct Paint Finish)
« Reply #1 on: December 02, 2018, 08:26:15 PM »
Does not appear to be a rebuilt unit but a replacement
Guess your building a non AC car (didn't include that detail) - if so then the shape/design is not like originals. Original exterior body was two piece both sort of shaped line cups joined together in the center and covered with a black masking looking seal around the seam
Surprise :(
« Last Edit: December 02, 2018, 08:41:59 PM by J_Speegle »
Offline bullitt68
Re: 1968 GT 390 Heater Motor Non AC Verification (Correct Paint Finish)
« Reply #2 on: December 02, 2018, 09:24:01 PM »
Surprise :(
Thanks Jeff. Are they easy to come by by chance
Mike
« Reply #4 on: December 02, 2018, 10:23:07 PM »
Yes same design used for many years. Glossier black finish of the semi-gloss range for sure. For your time period of car don't believe I've ever seen any visible (once installed) engineering markings or dating so you don't have to worry that detail
Offline bullitt68
« Reply #5 on: December 03, 2018, 12:48:59 AM »
Great so as long as it has the same design I should be fine. Obviously the design I have is not acceptable
Mike
