Author Topic: 1968 Mustang J Code C4 Metuchen 1/68 Driveshaft Detail  (Read 1484 times)
Offline JeffWS
« on: December 01, 2018, 02:57:07 PM »
I would like to detail my 1968 Mustang GT 9" J Code C4 Metuchen 1/68 Driveshaft and I don't have the build sheet.
I am looking for demensions and colors of the driveshaft marks and/or a copy of someones build sheet.
Thank you.
Note: I have a copy of a J code 4 speed build sheet, and it indicates L B L U D G N W H T. ( light blue, dark green, white)
« Last Edit: December 01, 2018, 03:23:42 PM by JeffWS »
Jeff
Re: 1968 Mustang J Code C4 Metuchen 1/68 Driveshaft Detail
« Reply #1 on: December 02, 2018, 10:28:27 PM »
The buildsheet information you posted. Was it from another GT or a non-GT? Since they use different rearends.
If so are you now just looking for confirmation or details of what each color looked like and or their placement?
Offline Coralsnake
« Reply #2 on: December 04, 2018, 10:55:16 AM »
I think we can answer the question. According to the 1975 MPC there is only one driveshaft for the 1968 302 GT
It is the C8ZZ-4602-A
The stripes on that driveshaft are light blue, dark blue, pink
Have you looked at the main wiring harness for your build sheet? 1968 NJ cars almost always have them there.
Im surmising the other car is not a GT
« Last Edit: December 04, 2018, 11:00:58 AM by Coralsnake »
« Reply #3 on: December 04, 2018, 07:55:30 PM »
Since the 75 MPC would have only shown what was available at time of its printing was available for a replacement for the original driveline I thought I would double check a 68 MPC to see what, if any, light it could shine on the subject. I found that that MPC did not reflect what was used originally on the assembly line but instead lists replacements only and some, what I found, some details that don't make sense at this time
Can confirm that at least the buildsheet show, for GT J codes (non-GT's had at least two different drivelines) both automatic and manuals shared the same driveline. A somewhat unusual occurrence
Offline teamlo
« Reply #4 on: December 04, 2018, 08:06:09 PM »
My car in a '68 GT coupe, J-code, C4, San Jose build 12/67.  I don't have dimensions, but I do have some pretty good photos of the original, unrestored driveshaft if you're interested.
Terry
Offline DTruitt
« Reply #5 on: December 04, 2018, 08:29:02 PM »
Here is an older thread on the subject, one good picture still remains!
http://www.concoursmustang.com/forum/index.php?topic=2031.15
Danny
1968 Raven Black, S- Code, 4 spd., GT Fastback, San Jose, March 1968
1968 Candy Apple Red, J- Code, C-4, GT Convertable, San Jose, April 1968 (SOLD)
1968 Raven Black, R- Code, 4 spd., GT Coupe, Dearborn, April 1968
MCA Gold Card Judge
Offline JeffWS
« Reply #6 on: December 19, 2018, 09:59:55 AM »
Thank you for the responses.
The build sheet info that I included was from a non-GT.
Terry, I would like to see the pictures of your driveshaft.
I am looking for colors and placement of them.
I was able to locate my build sheet, but unfortunately there was only a few pieces.
Jeff
« Reply #7 on: December 20, 2018, 01:01:25 AM »
Considering what you posted above that us what I was expecting
Back to your original request
From 68 J code automatic GTs before and after your car was built I found Blue- Lavender - White.  Likely applied like the typical 68 drivelines since you have no original markings let to support a different choice at this point
Offline JeffWS
« Reply #8 on: December 20, 2018, 10:55:09 AM »
Terry sent me pictures of his 1968 GT, J-code/C4  Dec ‘67 build date San Jose plant driveshaft.
Looking at it from rear to front... it looks like 6-8 " there is a silver stripe, and then in the middle it looks like light blue - white - lavender.
Jeff, Are his colors in a different order because it was built at a different plant?
Jeff
« Reply #9 on: December 22, 2018, 05:46:40 PM »
Think I have pictures of that driveline or at least another in the 8R116xxx range marked the same
To your question No the drivelines were not made at the car assembly plant so they did differ because different workers installed them. Though I don't know for certain right now if there were two or only one supplier (one would be odd) for all the plants. Its possible a batch (including that car's example) got marked incorrectly but because of the documentation have from the NJ plant and that the workers used that to identify them I would go with the order written on the buildsheet rather than what is possibly a small number of mis-marked drivelines installed at another plant on the other side of the country.
Offline JeffWS
« Reply #10 on: December 24, 2018, 09:23:12 AM »
Thanks Jeff.
Jeff
Offline JeffWS
« Reply #11 on: March 22, 2019, 12:37:45 PM »
I had my driveshaft balanced and then took a scotch brite pad to the shaft and found some color stripes.
Measuring from back to front...
10 3/4" (3/16 wide) orange/brown? (I am not sure about the color)
12" (3/16" wide) orange/brown?
22" (1/2" wide) white
25" (1" wide) pink
28" (3/4 wide) red
1968 New Jersey 1/68 built J code C-4 GT 9" rear
Jeff
