I recently purchased this book to use as a reference for finishes, but it is fairly generic as it does not take into account the discrepancies between the 3 plants. So my question is what should the correct finishes be for all if the 4 parts for each side as per attached photos. 2 mounts goes on the block and then there are 2 pieces that make up the frame mount. My mounts had yellow paint marking on one side and white on the other, but the books says the marks should be yellow on one side and green on the other, so I just want to confirm what would be correct. Also there are no part numbers or date codes or any other stamps on these parts other than a "R" stamped on the right side. Are these correct mounts or should they be stamped with logo and date codes etc.
Any photos would be appreciated.
