Author Topic: Wheels 14x7 KH Slotted Wheels set of 4 (optional in '70) ?  (Read 1272 times)
Offline HDAshmore
« on: November 21, 2018, 03:03:28 PM »
Happy Thanksgiving All,
Were KH slotted 14x 7 wheels optional for 70 Mach 1?  Also my assumption is if they were, how would they be listed on the Marti Report and what color is the actual wheel?  Finally did all come with the same beauty rings and dog dish?
Thanks, Dan
Re: Wheels 14x7 KH Slotted Wheels set of 4 (optional in '70) ?
« Reply #1 on: November 21, 2018, 05:25:34 PM »
Believe so - if not someone will surely set us right
Unless an item is part of a package Kevin typically list optional items in the list at the bottom of the page of his reports.
Might want to do a search can't recall if someone has posted a current paint code for the dark charcoal. I choose to go with powder coating (don't tell anyone)  on my last set - non-restoration project  ::)
Follow up did find this note in my notes from the 90's. Code is an older PPG/Diltzler one. May be close or a match for the wheels
"Medium Gray Poly DDL33053 Lacquer, correct color for 70 Mach 1 rockers, grille, sport wheelcovers. Use flattener on grille area. Tint with black to match original pieces if available."
Yes
« Last Edit: November 21, 2018, 05:36:43 PM by J_Speegle »
Offline HDAshmore
« Reply #2 on: November 21, 2018, 05:57:45 PM »
Jeff,
Awesome thanks for the wisdom.
Dan
Offline cobrajet_carl
« Reply #3 on: November 22, 2018, 08:05:34 PM »
Thanks, Dan
My Marti and invoice lists "Argent Styled Steel Wheels" as a no cost option, if that is what you were asking about.
Carl
70 and 71 Dearborn mach Is
Offline HDAshmore
« Reply #4 on: November 26, 2018, 12:36:12 PM »
Carl,
Thanks.
Dan
Offline ExportMach
« Reply #5 on: November 27, 2018, 01:30:56 PM »
Carl
Your Mach was built two days ahead of my Mach at the same plant !!
Mark C
