I have San Jose built 13G D code with San Jose DSO, PCV and hose from oil fill cap to the side of the air cleaner (closed emissions). It uses the screw-on adapter for the oil fill cap hose attachment to the air cleaner. My understanding is that the late May 64 change back to road draft setup was not implemented in California at all. Tough call on actual build date since I don't have the build sheet, but the car has a very low VIN.
None of the 64 1/2 K codes got road draft tubes - I established with Bob Mannell that the rear of the intake mounted road draft tube interferes with the Hipo exhaust manifolds - in fact it comes down right in the middle of where the exhaust manifold outlet is. (Bob has since made a change to the supplemental change notes in the his small block Ford book on this subject.) In addition, the 64 1/2 K code used the C4OF BT carb according to Ford literature, but the late Jon Enyeart of Pony Carbeurators told me back in the late 2000s that he had never seen a C4OF BT. I am aware of some early 65 K codes (including Fairlane) that have the later K code road draft tube mounted on the RH valve cover where the PCV would otherwise go, but they have the C5 hipo carb on them.
-Scott
