Author Topic: Installing Front Fender  (Read 1628 times)
Offline 69GT350H
« on: November 05, 2018, 05:43:05 PM »
Does the bolt clip go on the ear by the cowl or on the tab on the fender? I thought it went on the ear but then my light bucket hits the radiator support and prevents the fender from moving back when I try to pull tab behind the ear. I've looked at the illustrated manual and the shop manual but neither clarify this issue.
Re: Installing Front Fender
« Reply #1 on: November 05, 2018, 11:26:45 PM »
Other way around. Fender clip is forward of the bracket attached to the A pillar
J clip is installed on the bracket attached to the fender so that the bolt can be installed from the direction the photo was taken from and tightened
Offline 69GT350H
« Reply #2 on: November 06, 2018, 10:26:47 AM »
Thanks, got the same answer over on VMF yesterday. Was a standard fender bolt used as that ear on the cowl/A Pillar has a pretty big square hole in it. That will all for a bit of adjustment though.
