Author Topic: 1966 Condensor Mounting Order?  (Read 560 times)
Offline 66RavenGTCoupeAgain
« on: October 31, 2018, 07:34:49 PM »
Hi Guys,
I was just wondering if someone can confirm the order of installation for me?
Is it Condensor mounted from outside of Radiator Support panel and then fan shroud mounts and then radiator and nuts or is it
Condensor mounted from outside of Radiator Support panel and then radiator, then fan shroud mounts and then nuts?
Thanks in advance,
Daniel
66 Metuchen NJ  GT Coupe
6T07A1612## Dec 65 Build
5R08C1496## Oct 64 Build
Re: 1966 Condensor Mounting Order?
« Reply #1 on: October 31, 2018, 10:47:09 PM »
Condenser, radiator, fan shroud brackets, nuts.
« Reply #2 on: November 01, 2018, 08:52:28 PM »
Thanks Charles. Just thought that the square indentations around the mounting holes in the radiator support looked like they were there to receive the brackets. I know that in a non AC car, the speed nuts slide into this indentation to allow the radiator to mount flush with the support panel but it just looked like a "nice fit" for the brackets too so it made me ask the question.
« Reply #3 on: November 02, 2018, 10:22:54 AM »
The orientation should also be in the Osborne assembly manuals.  Recommended to buy a set.
