Author Topic: 1964.5 Door Plug -To Paint or Not to Paint  (Read 1709 times)
Offline RAH2 1964.5
« on: October 26, 2018, 07:07:43 PM »
I am asking whether I should paint the door plugs for the window adjustment holes or not. See pics. I have looked at other links on the topic including the one below. I have learned that the plugs were the body color except for the first few weeks of production which were natural zinc unpainted. They were painted off the car. The build date for my car is May 8, 1964. So, paint or not to paint – or take Charles Turner suggestion:
For concours showing, personally, I might be inclined to spray another set with body color and have them available in case a judge decides they don't want to accept them as non-painted.
What is the vote?
https://www.concoursmustang.com/forum/index.php?topic=1594.msg8064#msg8064
« Last Edit: October 26, 2018, 08:06:40 PM by RAH2 1964.5 »
Thanks Roger
05/08/64, Dearborn, Convert., DSO Phil.
Raven, Stand. Int., White with Black Trim
AT, 260v, PS, Console
2003 Cobra Convert., Torch Red, 10th Anniv., Stock
2006 GT Coupe, Redfire, Factory Stripes, Stock (Shaker Intake)
Re: 1964.5 Door Plug -To Paint or Not to Paint
« Reply #1 on: October 26, 2018, 10:33:53 PM »
They should be painted on a May ‘64 car.  I have examples of April ‘64 cars with painted plugs.
Offline RAH2 1964.5
« Reply #2 on: October 27, 2018, 10:37:44 AM »
Thanks Roger
Offline RAH2 1964.5
« Reply #3 on: October 27, 2018, 06:07:14 PM »
One Question - Would it matter which Plant? Mine is Dearborn.
Thanks Roger
« Reply #4 on: October 27, 2018, 06:22:16 PM »
The other two plants were not in production yet. So only one plant ;)
Offline RAH2 1964.5
« Reply #5 on: October 27, 2018, 06:28:12 PM »
I knew that.   :o
Thanks Roger
Offline NEFaurora
« Reply #6 on: October 28, 2018, 12:58:28 AM »
Just for info.... Dearborn (Allen Park Pilot Plant) Mustang VIN#1.....Painted Plugs... Original Paint car....as well.
I'd like to see some early pics of Original cars with Unpainted Plugs... It's been so long that I don;t remember seeing too many...
:o)
Tony K.
« Last Edit: October 28, 2018, 01:00:56 AM by NEFaurora »
MCA#70001
« Reply #7 on: October 28, 2018, 01:47:06 AM »
Originally the plugs had a thin foam gasket . Sometimes you could see the edge of the foam around the plug. It turns to dust many times because of age which is why it is not often seen.
« Reply #8 on: October 28, 2018, 02:28:47 AM »
Thought I recalled that the car had been repainted. What do others know?
Offline RAH2 1964.5
« Reply #9 on: October 28, 2018, 03:24:09 PM »
When did the other two plants begin production?
Thanks Roger
« Reply #10 on: October 28, 2018, 05:18:36 PM »
100211, an 09C car, has unpainted plugs.  It also has the early doors with no grommet for the lock knobs.
« Reply #11 on: October 28, 2018, 05:46:21 PM »
San Jose is reported to have started production on July 13, 1964
NJ not until 65 production started
Offline NEFaurora
« Reply #12 on: November 05, 2018, 10:06:30 PM »
"Thought I recalled that the car had been repainted. What do others know?"
Not that I've even heard of... Ford took possession of the car in 1966 and donated it to the Henry Ford Museum in 1975 or thereabout I believe.  Even if you go out on a limb and say that the car was re-painted for Late '70's- Early 80's Publicity shots (which the car figured in prominently back then)...You can see that the Door Jambs had not been re-painted and it looks like they carry their Original paint...
:o)
Tony K.
MCA#70001
« Reply #13 on: November 05, 2018, 11:30:44 PM »
Don't have any of those pictures from the 80s when the car was being promoted/shared for the first anniversary shows that Ford sponsored, that show enough detail or are close enough IMHO to determine if they it was or was not repainted.  Just going by what at least one person that saw the car up close stated.
Do you have any pictures with enough detail to show the door bumpers, around the door tag or other areas?
Offline NEFaurora
« Reply #14 on: November 06, 2018, 05:10:39 PM »
Got quite a few... What areas would you like to see Jeff of VIN#100001....???!!??  Collected around 100 good pics from the last 20+ years... some really good up close ones just from the last 10 years...
:o)
Tony K.
« Last Edit: November 06, 2018, 05:14:13 PM by NEFaurora »
MCA#70001
