Author Topic: '64.5-'66 Convertible quarter window handles?  (Read 1286 times)
Offline 5F08KGT
« on: October 25, 2018, 02:41:09 PM »
Is there a difference in these like the front ones?
Re: '64.5-'66 Convertible quarter window handles?
« Reply #1 on: October 25, 2018, 04:40:14 PM »
Since your covering that large period - yes there are differences
Offline 5F08KGT
« Reply #2 on: November 05, 2018, 07:58:12 AM »
 So, Obviously a 64.5 clip on style regulator won't accept a late '65 or '66 style screw on handle then.....
« Reply #3 on: November 05, 2018, 10:24:24 AM »
The rear coupe/convertible window handles all have set screws, they don't clip on the early door handles or attach like the later ones.
Offline 5F08KGT
« Reply #4 on: November 07, 2018, 11:13:14 AM »
Thanks Charles.
Offline Hipo giddyup
« Reply #5 on: November 07, 2018, 12:08:18 PM »
This question would of course be regarding the front mechanism's only as Charles mentioned... But, to answer the question, they will if you drill and tap them. I have done this on a few before to retain a good Ford unit (just did it for my recent 66' coupe project as I had a perfect, early 65' regulator on the shelf). If done correctly, it works as it should and no one can tell.  ;)
« Reply #6 on: November 07, 2018, 12:27:32 PM »
The shape of the front and rear window cranks are different, it wouldn't be concours correct to use a front in the rear (only mentioning as this is the focus of this site).
« Reply #7 on: November 07, 2018, 03:49:01 PM »
 Just to be on the same page. What I referred to is taking a 65' window regulator assembly , drilling and tapping it to be able to be used in a 66' coupe with the 66' screw on handle.
I agree with you Charles. Using the larger front handle in the back would NOT be correct nor look right, IMHO. And vise versa..
« Reply #8 on: November 07, 2018, 05:29:22 PM »
Ah, didn't see the 'regulator' comment.  Thanks
