Author Topic: Tilt steering woes  (Read 1470 times)
Offline CCP
Tilt steering woes
« on: October 22, 2018, 12:06:46 PM »
   Have a '70 Cougar in the shop with tilt steering. The tilt does not seem to lock in place, and it has sort of a racheting up and down movement. Has anyone encountered this before. Is it broken or perhaps something loose in the column? Maybe an adjustment. I've never had on apart before, so I thought I would ask.
           Thanks,  Pete.
1969 Fairlane Cobra formal roof drag pack
1968 Shelby GT500KR
6F08A-GT,a/c,4-sp.,ps,build date 16A. DSO 24 Jacksonville
Re: Tilt steering woes
« Reply #1 on: October 22, 2018, 12:44:07 PM »
The pins on the knuckle may have backed out.  Check on west coast classic cougar website.  They sell repair parts or can rebuild the column.
Offline 69GT350H
« Reply #2 on: October 22, 2018, 12:44:19 PM »
See if this helps identify your problem.
Offline CCP
« Reply #3 on: October 22, 2018, 01:16:22 PM »
  Thanks guys. Got the steering wheel off and the lower plastic column cover. There is indeed a small pin that has backed out of the 'cog' that locks the column in place. The video was very helpful too. Going to attempt a repair.
                     Thanks again,  Pete.
1968 Shelby GT500KR
« Reply #4 on: October 22, 2018, 02:30:36 PM »
WCCC sells a repair kit with the E-clips on the ends of the pins, best solution for the issue and it will ensure no repeat failure of the same.
Offline CCP
« Reply #5 on: October 22, 2018, 03:18:53 PM »
  Thanks guys, will look into the repair kit.
1968 Shelby GT500KR
