Author Topic: 1966 dash harness replacement tips and best repro  (Read 1312 times)
Offline Hipo giddyup
« on: October 15, 2018, 11:33:29 PM »
Hi all. Finally having to replace the under dash harness due to wiring issues. Any tips/ lessons learned on doing this ??? Any one have opinions on who makes the best repro harness? Thanks for a reply!!
This will be for my 1966 Metuchen coupe, automatic, no AC.
Re: 1966 dash harness replacement tips and best repro
« Reply #1 on: October 16, 2018, 12:12:01 AM »
Lay the new harness out. I put a blanket on my hood with the new harness going where it would wind up. That's to get twists and bends out. Use the 66 Mustang Electrical Assembly Manual a lot. Remove the heater, the glove box, ash tray, radio, speakers, console, and seats. Have in place the windshield wiper motor, courtesy lights, LH vent, pedals.
I used a coat hanger to pull wired across, twist ties to hold sections in place. Blue painters tape might work too.
« Reply #2 on: October 16, 2018, 03:46:28 PM »
Thanks Jim, good pointers. Did you use a repro harness, good used, or NOS? Curious if anyone has used the dash harness from Alloy Metal. I have been pleased with their other harness'.
« Reply #3 on: October 16, 2018, 07:46:15 PM »
Mine was NOS. It was at least 25 years ago when they were "cheap". Sometime in the past, the original harness was modified to add a stereo - in several different places (I detest amateurs that cut and splice). The wrapping tape was almost non-existent. I removed the old harness, "repaired" the several splices, re-wrapped with 3M non-adhesive tape (a sample roll, it's good to know sales reps), and installed it in another 66 that was in worse shame than mine. There's a "trick" to getting the connectors out their holes in the firewall, and it escapes me right now (I will not pull one to "remember" the trick).
« Reply #4 on: October 16, 2018, 08:05:55 PM »
............Curious if anyone has used the dash harness from Alloy Metal. I have been pleased with their other harness'.
Have for later cars. Sometimes they had the wires inserted in the firewall incorrectly (only a couple) haven't heard any reports of this recently on the boards. Overall would use them again if I needed to. Might want to PM Coralsnake here on the site ;)
« Reply #5 on: October 17, 2018, 09:26:04 PM »
The trick is to use channel locks to depress the tabs top and bottom on one side by squeezingf, push the connector/metal tab in, then go to the other side and depress those two tabs and do the same.
« Reply #6 on: October 18, 2018, 12:11:42 AM »
The trick is to use channel locks -
I knew the trick was to use channel locks, I didn't want the rest of the procedure to be a problem. Thanks. Glad to see you are "up and about".
Offline rrenz
« Reply #7 on: October 23, 2018, 10:03:48 PM »
For what its worth I've replaced every harness on my car EXCEPT the under dash with alloy metal products. Been very pleased with them.
Ryan
C-4 Automatic
Build Date Jan 21st
2001 3.8 Mustang Convertible
2004 40th Anniversary
