Author Topic: 69 E Brake Routing  (Read 3416 times)
69 E Brake Routing
« on: October 15, 2018, 05:13:21 PM »
Posted a response on another forum and though I would post the same info over here to help members currently and in the future.
Here are some pictures of a 69 Dearborn installation that might help
Short cable from under dash attaches to the long main e brake cable. Short cable is attached to the bracket welded between the frame rail and cross member. On the other side a arm (shaped like a flattened "C" holds and routes the long cable towards the rear on the other side. Attached to a bracket welded to the floor.
Long cable attached to the rear frame rails at the rear under the rear seat riser
Cable ends attach to the rear brake backing plates and to the activating arm on each side
Hope they help
« Last Edit: October 18, 2018, 03:29:53 PM by J_Speegle »
Re: 69 E Brake Routing
« Reply #1 on: October 16, 2018, 08:07:47 AM »
jeff the cable bracket by adjuster 2 nuts needs to be flipped so cable is on top side to help clear exhaust better as thats the way i have seen from factory anyway & its a common mistake made on restorations during reassembly.
« Reply #2 on: October 16, 2018, 03:08:50 PM »
Interesting adjusting nut on the Dearborn car.  Different set up on my Metuchen car ?  Brian
« Reply #3 on: October 16, 2018, 08:14:16 PM »
Thanks Ed for catching that. Corrected now ;)
If you notice the system does not appear to have been adjusted when the picture was taken - assembly was still going on. Barely any of the threaded shaft was showing through.  In the original picture posted there had only been one nut installed, just to hold things in place for the moment I would guess. Good eye :)
Offline PerkinsRestoration
« Reply #4 on: October 18, 2018, 01:55:37 PM »
Jeff, The spring retainer (Pink Arrow in picture)is typically installed on the other end of spring. ;)
« Reply #5 on: October 18, 2018, 03:30:42 PM »
Thanks Bob for taking the time and mentioning that. Its been corrected for the viewers  :)
