Author Topic: HEH Verses RUG Toploader Transmission  (Read 2164 times)
Offline Boss980
« on: October 14, 2018, 09:27:52 AM »
I understand the designated HEH code toploader was used in earlier FORD cars then after 67 used the RUG series toploader.
But what was the difference in the two Transmissions?
I have a HEH-BW toploader originally used in 66 289 mustang and I want to use it in my stock 69 351w mustang. (Originally the 69 used the RUG code)
When I ask they say yes it will work fine but I'm wondering what's the difference in the HEH verses the RUG
(I will be using an after market Competition Plus Hurst shifter, but haven't got a shifter kit yet)
Many Thanks
Offline Boss980
Re: HEH Verses RUG Toploader Transmission
« Reply #1 on: October 14, 2018, 11:12:50 AM »
I know the same main case was used, and even the same tail housing C4ZR for the mustang up to 73 but what was the difference in the transmission of the two?
Offline Texas Swede
« Reply #2 on: October 14, 2018, 11:24:53 AM »
I have heard somewhere that the difference is the lack of a drain plug in the RUG housing.
Texas Swede
Offline 7Lscjracer
« Reply #3 on: October 14, 2018, 05:25:40 PM »
RUG-E3 1969 302/351 Mustang/Cougar would be the 28 spline wide ratio equivalent to your HEH-BW, so you're good to go as far as I know.
Bought May '81, sold Sept '20
Offline AU Finger
« Reply #4 on: November 06, 2018, 05:30:18 PM »
Years ago I had been told that there was a difference of the amount of nickel content in the cast material.  Higher in the earlier casings, differential carrier housings, cylinder blocks, heads, and intake manifolds as well.  High performance applications still received the higher nickel content (such as CJ intakes and nodular carriers).  I can not confirm this information though.
May 25, 1964 D code convertible
Offline TLea
« Reply #5 on: November 08, 2018, 08:17:42 PM »
Texas Swede
Drain plugs not dropped till 70
