Author Topic: 67 GT Grille fog light support bracket color  (Read 461 times)
Offline Jaybart68
« on: October 13, 2018, 01:40:38 PM »
I’m refishing the grille on my 67 GT. My understanding after searching through posts and unrestored pictures is:
- the grille is to be painted before the vertical supports, fog light supports and top brackets are installed (I’m using NPD’s 67 bluish grey metallic for that)
- the 3 vertical support brackets as well as the two top brackets get riveted in (1/8 x 1/8 steel semi tubular rivets)
- fog light support brackets installed using u nuts and screws
My question: are the 3 vertical brackets, the two top brackets and the fog light supports all semi gloss black? Or is there some other finish to be applied?
Jay Barthel
1967 (12/22/66, Dearborn GT Fastback, 390-4V, DSO 41, 4 speed manual, standard black interior, ext. Decor, Raven Black, +options)
Re: 67 GT Grille fog light support bracket color
« Reply #1 on: October 13, 2018, 05:00:19 PM »
All semi-gloss but I believe they were originally dipped (not sprayed).
Does NPD have this paint available now?
Offline Jaybart68
« Reply #2 on: October 13, 2018, 05:07:26 PM »
Yes. SGB it is then. How can one tell dipped from sprayed?
Jay Barthel
« Reply #3 on: October 13, 2018, 05:10:51 PM »
... How can one tell dipped from sprayed?
Not easy at a glance but typically you will notice runs, drips at corners and such. You can give them a light spray coat, let tack-dry and hose them heavy and get similar results out of a spray can too.
